Hi, I'm doing a radar with my ht sr04 ultrasonic sensor. The arduino code is this:
// Sweep
#include <Servo.h>
#define trigPin 13
#define echoPin 12
long previousMillis = 0;
long previousinterval=300;
long newinterval; // interval at which to blink (milliseconds)
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 5; // variable to store the servo position
{ Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
unsigned long currentMillis = millis(); // milliseconds
if(currentMillis - previousMillis > previousinterval) {
myservo.write(90);
int duration;
int distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/56);
//Serial.print(distance);
//Serial.println(" cm");
if (distance <= 10 ){
for(pos = 0; pos <= 180; pos += 10) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
int duration;
int distance;
//Serial.print("X");
//Serial.print(pos);
//Serial.print("V");
Serial.println(distance);
delay(800);
myservo.write(pos); // tell servo to go to position in variable 'pos'
for(pos <= 180; pos>=0; pos-=10) // goes from 0 degrees to 180 degrees
int duration;
int distance;
delay(800);
} // waits 15ms for the servo to reach the position
I want Processing to read the position of the servo and the distance value and plot a point on a screen. I found several projects online, for example this http://luckylarry.co.uk/arduino-projects/arduino-processing-make-a-radar-screen-to-visualise-sensor-data-from-srf-05-part-2-visualising-the-data/, and I tried to write my own code. However, since I'm new in the arduino word, I can't figure out how to read the serial port in Processing. This is the code I made in order to read the distance alone:
// Learning Processing
// Daniel Shiffman
// http://www.learningprocessing.com
// Example 19-8: Reading from serial port
import processing.serial.*;
int val = 0; // To store data from serial port, used to color background
Serial port; // The serial port object
size(200,200);
// In case you want to see the list of available ports
// println(Serial.list());
// Using the first available port (might be different on your computer)
port = new Serial(this, Serial.list()[0], 9600);
void draw() {
// The serial data is used to color the background.
//background(val);
// Called whenever there is something available to read
void serialEvent(Serial port) {
// Data from the Serial port is read in serialEvent() using the read() function and assigned to the global variable: val
val = port.read();
println( "Raw Input:" + val);
However, instead of the value of the distance sensor I get these strange values:
Raw Input:51
Raw Input:53
Raw Input:13
Raw Input:10
Raw Input:51
Raw Input:54
Raw Input:13
Raw Input:10
Raw Input:51
Raw Input:53
Raw Input:13
Raw Input:10
Raw Input:50
Raw Input:56
Raw Input:13
Raw Input:10
Raw Input:50
Raw Input:54
Raw Input:13
Raw Input:10
what should I do?
