Ultrasonic sensor problem
So I was making an obstacle avoiding car and wrote this elaborate code which had a couple of errors but i removed them. However my car should turn when the ultrasonic sensors value for distance is equal to or lesser than zero but when i tested the code out, my car just went up and rammed in to the obstacle i.e door in this case. My ultrasonic also returns somwhat arbitrary values in between a set of normal values. Can someone kindly help me out? Feel free to go through the code again.
I have also attached a photo of serial monitor when the car is stationary.
Obstacle avoiding car.txt (4.34 KB)
Do not double post.
Please read and follow the directions in the "How to use this forum" post, and post code properly, using code tags.
