Hi everyone,
I’m working on a project where I need to use two ultrasonic sensors to determine the position of an emitter connected to a separate board. When the ultrasonic emitter sends out a signal, the two sensors, which are connected to the same board, will receive the signal at different times due to the distance between them. By measuring this time difference, I want to determine if the emitter is located to the right or left of the sensors.
Project Details:
• The sensors are approximately 50 cm apart.
• The emitter will be located at a maximum distance of about 5 meters from the sensors.
I would appreciate your advice on which ultrasonic sensor and emitter would be best suited for this application.
Thanks in advance!
