Ultrasonic Sensor TUB01
Dear Friend.
has anyone ever tried the Ultrasonic fuel sensor TUB01 with MAX3243C converter to communicate with Arduino?
if someone has tried can share here? this sensor has RX TX on the output cable
This URL for image ultrasonic sensor TUB01 :
https://www.google.com/search?safe=strict&biw=1517&bih=730&tbm=isch&sa=1&ei=qMihXKn5B6zaz7sP8uWnqA0&q=ultrasonik+TUB01&oq=ultrasonik+TUB01&gs_l=img.3...28275.28275..28836...0.0..0.67.67.1......1....1..gws-wiz-img.TlU7-gJ4unI#imgrc=NRDaucpll3mztM:
Can connect to arduino via an rs232 <-> ttl converter (easy to build)
You will need to know HOW to talk to the sensor— its detailed protocol
knut_ny:
FYI sir,
this sensor propagates inside a liquid instead of in the air,
can u show me the program or link website to learn it?
Thanks before
There is not much to find for your sensor.. https://www.youtube.com/watch?v=MSHlL8BMqHY If the max3243-chip is a part of the sensor ??, i may connect directly to Arduinos serial-port (datasheet)
