Ultrasonic sensor with 433 mHz radio module problem
Hello guys, I am currently making a system which displays the distance of a ultrasonic sensor (HC SR 04 )via a 433 mHz radio module.
When I upload both of my codes, the serial monitor prints numbers like
"E35363132382". It would be awesome if someone can help me out.
Thx in advance.
Transmitter code
#include <VirtualWire.h> //Load the library
#include <SPI.h>
#include <Wire.h>
#define trigPin 10
#define echoPin 9
float duration, distance;
char msg[4];
    vw_set_tx_pin(12);          // Sets pin D12 as the TX pin
    vw_setup(2000);          // Bits per sec
    pinMode(trigPin, OUTPUT);
    pinMode(echoPin, INPUT);
     digitalWrite(trigPin, LOW);
     delay(10);
    digitalWrite(trigPin, HIGH);
     delay(10);
    duration = pulseIn(echoPin, HIGH);
    distance = duration/2/29.1;
    Serial.print("Distance: ");
    Serial.println(distance);
    dtostrf(distance, 6,2,msg);           //converts the float into a char
    vw_send((uint8_t *)msg, strlen(msg)); //transmits the data
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite (12,0);
    delay(200);
RECEIVER CODE
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
int i;
  Serial.begin (9600);
  vw_set_rx_pin(12);
  vw_setup(2000);
  vw_rx_start();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if ( vw_get_message(buf, &buflen) )
    for (i = 0; i < buflen; i++)
      Serial.print(buf[i]);         // this is the part where I think it went wrong, the //receiever does receiver data but I think it isnt in the correct type. I am supposed //to get the distance in centimeters, so about couple digits like 123,45
I solved the problem, it is by adding float distance = atoi(strtok((char*)buf, ",")); after the for function in receiver loop.
This is another and more serious problem. msg[] can hold only 3 characters, so you are writing to memory that you don't own. Make it larger.
would char msg [6] or 7 better ? is that what you mean?
also, thanks
You must allocate at least as much space as you ever expect to use. If you don't, your program will crash unpredictably.
thank you for your advice
Sorry to intertupt, but do u have time to look at another iusse of mine?
