Hello, relatively new in all of this so I am stuck with combining ultrasonic HC-SR04 into my code. Basically I am making Bluetooth remote car (which is working) and now I need to write code which will not allow me to go forward when sensor detects distance less then 30cm for example.
We can't see the code you're trying to combine.
#include <AFMotor.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(A4, A5);
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
char command;
mySerial.begin(9600);
void loop(){
if(mySerial.available() > 0){
command = mySerial.read();
Stop();
switch(command){
case 'F':
forward();
case 'B':
back();
case 'L':
left();
case 'R':
right();
void forward()
motor1.setSpeed(255);
motor1.run(BACKWARD);
motor2.setSpeed(255);
motor2.run(BACKWARD);
void back()
motor1.run(FORWARD);
motor2.run(FORWARD);
void left()
void right()
void Stop()
motor1.setSpeed(0);
motor1.run(RELEASE);
motor2.setSpeed(0);
motor2.run(RELEASE);
This is the code without any parts for ultrasonic which works without problem, I just don't know how to write ultrasonic part. Never worked with it so yeah. Anything helps
A common mistake is to take range readings too frequently.
You should try not to exceed more than about 20 to 30 readings per second.
