Ultrasonic sensors problem
Hello guys
the problem:
I have 4 HC-SR04 connected on Arduino Mega
as response 1 or 2 of them gives me randomly a “0” as distance which mess up my code to control dc motor.
I tried different sensors timing but nothing changes(right now is 200 ms)
this is the serial output:
0=59cm 1=0cm 2=0cm 3=32cm
FWD A
FWD B
FWD B
FWD A
0=59cm 1=48cm 2=12cm 3=31cm
FWD A
FWD B
FWD A
0=57cm 1=0cm 2=0cm 3=0cm
FWD A
FWD B
FWD B
FWD A
BKW A
0=58cm 1=47cm 2=0cm 3=22cm
this is the code:
// This example code was used to successfully communicate with 15 ultrasonic sensors. You can adjust
// the number of sensors in your project by changing SONAR_NUM and the number of NewPing objects in the
// "sonar" array. You also need to change the pins for each sensor for the NewPing objects. Each sensor
// is pinged at 33ms intervals. So, one cycle of all sensors takes 495ms (33 * 15 = 495ms). The results
// are sent to the "oneSensorCycle" function which currently just displays the distance data. Your project
// would normally process the sensor results in this function (for example, decide if a robot needs to
// turn and call the turn function). Keep in mind this example is event-driven. Your complete sketch needs
// to be written so there's no "delay" commands and the loop() cycles at faster than a 33ms rate. If other
// processes take longer than 33ms, you'll need to increase PING_INTERVAL so it doesn't get behind.
#include <NewPing.h>
#define SONAR_NUM     4 // Number of sensors.
#define MAX_DISTANCE 300 // Maximum distance (in cm) to ping.
#define PING_INTERVAL 200 // Milliseconds between sensor pings (29ms is about the min to avoid cross-sensor echo).
unsigned long pingTimer[SONAR_NUM]; // Holds the times when the next ping should happen for each sensor.
unsigned int cm[SONAR_NUM];         // Where the ping distances are stored.
uint8_t currentSensor = 0;          // Keeps track of which sensor is active.
NewPing sonar[SONAR_NUM] = {     // Sensor object array.
  NewPing(26, 27, MAX_DISTANCE), //  FRONT SENSOR  Each sensor's trigger pin, echo pin, and max distance to ping.
  NewPing(28, 29, MAX_DISTANCE), // DX SENSOR
  NewPing(24, 25, MAX_DISTANCE), //LX SENSOR
  NewPing(22, 23, MAX_DISTANCE), // BACK MSENSOR
//  NewPing(23, 24, MAX_DISTANCE),
//  NewPing(25, 26, MAX_DISTANCE),
//  NewPing(27, 28, MAX_DISTANCE),
//  NewPing(29, 30, MAX_DISTANCE),
//  NewPing(31, 32, MAX_DISTANCE),
//  NewPing(34, 33, MAX_DISTANCE),
//  NewPing(35, 36, MAX_DISTANCE),
//  NewPing(37, 38, MAX_DISTANCE),
//  NewPing(39, 40, MAX_DISTANCE),
//  NewPing(50, 51, MAX_DISTANCE),
//  NewPing(52, 53, MAX_DISTANCE)
//Motor  LX;
int dir1PinA = 13;
int dir2PinA = 12;
int speedPinA = 10;
//motor RX;
int dir1PinB = 11;
int dir2PinB = 8;
int speedPinB = 9;
pinMode (dir1PinA, OUTPUT);
pinMode (dir2PinA, OUTPUT);
pinMode (speedPinA, OUTPUT);
pinMode (dir1PinB, OUTPUT);
pinMode (dir2PinB, OUTPUT);
pinMode (speedPinB, OUTPUT);
  pingTimer[0] = millis() + 100;           // First ping starts at 75ms, gives time for the Arduino to chill before starting.
  for (uint8_t i = 1; i < SONAR_NUM; i++) // Set the starting time for each sensor.
    pingTimer[i] = pingTimer[i - 1] + PING_INTERVAL;
  for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through all the sensors.
    if (millis() >= pingTimer[i]) {         // Is it this sensor's time to ping?
      pingTimer[i] += PING_INTERVAL * SONAR_NUM;  // Set next time this sensor will be pinged.
      if (i == 0 && currentSensor == SONAR_NUM - 1) oneSensorCycle(); // Sensor ping cycle complete, do something with the results.
      sonar[currentSensor].timer_stop();          // Make sure previous timer is canceled before starting a new ping (insurance).
      currentSensor = i;                          // Sensor being accessed.
      cm[currentSensor] = 0;                      // Make distance zero in case there's no ping echo for this sensor.
      sonar[currentSensor].ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
  // Other code that *DOESN'T* analyze ping results can go here.
void echoCheck() { // If ping received, set the sensor distance to array.
  if (sonar[currentSensor].check_timer())
    cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
void oneSensorCycle() { // Sensor ping cycle complete, do something with the results.
  // The following code would be replaced with your code that does something with the ping results.
    Serial.print(i);
    Serial.print("=");
    Serial.print(cm[i]);
    Serial.print("cm ");
// GO forward
 if (cm[0] >= 30){
 //if (cm[0] <= 30 && cm[0] != 0) // CENTER SENSOR
    analogWrite (speedPinA, 255);
    analogWrite (speedPinB, 255);
    digitalWrite (dir1PinA, LOW);
    digitalWrite (dir2PinA, HIGH);
    digitalWrite (dir1PinB, LOW);
    digitalWrite (dir2PinB, HIGH);
    //delay(50);
    if (dir2PinA = HIGH)
    Serial.println("FWD A");
    if (dir2PinB = HIGH)
    Serial.println("FWD B");
    if (cm[0] <= 30){
       //-----------------------------------motors back
    analogWrite (speedPinA, 150);
    digitalWrite (dir1PinA, HIGH);
    digitalWrite (dir2PinA, LOW);
    analogWrite (speedPinB, 150);
    digitalWrite (dir1PinB, HIGH);
    digitalWrite (dir2PinB, LOW);
    if (dir1PinA = HIGH)
    Serial.println("BKW A");
    if (dir1PinB = HIGH)
    Serial.println("BKW B");
    //---------------------------------------------RIGHT SENSOR
if (cm[1] <= 15) {
    // MOTORS TURN RIGH M
    analogWrite (speedPinA, 0);
  if (dir1PinA = LOW)
    Serial.println("STOP A");
if (cm[2] <= 15 ) { // LEFT SENSOR
    // MOTORS TURN LEFT
    analogWrite (speedPinB, 0);
    if (dir2PinB = LOW)
    Serial.println("STOP B");
if (cm[3] <= 20) { // BACK SENSOR
    if (dir2PinA = LOW)
    if (dir2PinB = LOW)
if (cm[0] <=10 && cm[1] <=10) {
if (dir2PinA = LOW)
    Serial.println("BWD B");
if (cm[0] <=10 && cm[2] <=10) {
    Serial.println("BWD A");
//----------------------STUCK BACK RIGHT
if (cm[3] <=10 && cm[1] <=10) {
//------------------------STUCK BACK LEFT
if (cm[3] <=10 && cm[2] <=10) {
    if (dir1PinB = LOW)
Hardware:
Arduino mega, L298N Motor Driver shield
Thanks
Ok I am mapping the distance so to avoid the "0"
anyone can help wit map command?
thanks
You could be getting the numbers due to insufficient power. Put a 10uF cap between 5V and gnd on the sonic ranger. Mine was giving off some occasional random numbers before I added the cap.
Thanks
