I am creating an automatic lawnmower that can cut a lawn in a fenced off area and can detect objects and avoid them by cutting in a random cut order kind of like Roomba does.
Basically my code would make my lawnmower move forward till one of the sensors sensed something. Then depending on which sensor is tripped the lawnmower would stop, reverse, then finally rotate before moving forward again.
I have built my lawnmower in small scale to confirm my code was working correctly, but now when implementing my design into the real prototype my right sensor keeps sending a low signal never letting my lawnmower move forward and keep on stopping reversing then rotating infinitely.
Any ways on how to bypass/fix this problem would be greatly appreciated. The code I am using is below.
//amount of time to cut lawn
time_to_cut = millis();
while((millis() - time_to_cut) < interval){
//speed of the motor
analogWrite(speedPin,225); // originally 225
analogWrite(speedPin2,225); // originally 225
digitalWrite(trigPin1, HIGH); // this is telling the sensors to sense
delayMicroseconds(10);
digitalWrite(trigPin1, LOW);
duration1 = pulseIn(echoPin1, HIGH);
distance1 = duration1/58.2;
delay(50);
digitalWrite(trigPin2, HIGH);
digitalWrite(trigPin2, LOW);
duration2 = pulseIn(echoPin2, HIGH);
distance2 = duration2/58.2;
delay(50);
digitalWrite(trigPin3, HIGH);
digitalWrite(trigPin3, LOW);
duration3 = pulseIn(echoPin3, HIGH);
distance3 = duration3/58.2;
delay(50);
if(distance1 <= 20 || distance2 <= 20 || distance3 <=20){
if(distance1 <= 20){
randNumber = 0;
else if(distance3 <= 20){ //2nd if `
randNumber = 1;
else{
randNumber = random(2);}
randNumber2 = random(1000, 3001);
delay(10);
if(randNumber == 1){ //
digitalWrite(dir1, LOW);
digitalWrite(dir2, LOW);
digitalWrite(dir3, LOW);
digitalWrite(dir4, LOW);
delay(1000); //stop for 1 second
digitalWrite(dir1, HIGH);
digitalWrite(dir3, HIGH);
delay(2000); //reverse for 2 second
delay(randNumber2); //reverse front right motor
if(randNumber == 0){
delay(randNumber2); //reverse front left motor
else{}
else{
// Move
digitalWrite(dir2, HIGH);
digitalWrite(dir4, HIGH);
while((millis() - time_to_cut) > interval) {
