Ultrasonic sonic sensors controlling a robot
I have 3 HCsro4 ultra sonic senors attached to a arduino atMega with 4 motors running off motor controllers im having issues with this piece of code
   else if (CM2 < 30 && CM2 > 3)
     LPCOUNT =7 ;
      BackLeft.writeMicroseconds (1600);
     BackRight.writeMicroseconds (1400);
     FrontRight.writeMicroseconds (1400);
     FrontLeft.writeMicroseconds (1600);
       unsigned int CM1 = sonar.ping_cm();
        delay (50);
      unsigned int CM2 = sonar2.ping_cm();
          delay (50);
          unsigned int CM3 = sonar3.ping_cm();
  delay (50);
it constantly find this statement true heres the rest
#include <Servo.h>
#include <NewPing.h>
#define TRIGGER_PIN 53
#define ECHO_PIN 52
#define MAX_DISTANCE 400
#define TRIGGER_PIN2 50
#define ECHO_PIN2 51
#define MAX_DISTANCE2 400
#define TRIGGER_PIN3 49
#define ECHO_PIN3 48
#define MAX_DISTANCE3 400
int LPCOUNT = 0;
Servo BackLeft;
Servo BackRight;
Servo FrontLeft;
Servo FrontRight;
NewPing sonar (TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // SETUP for 1st ultrasonic sensor
NewPing sonar2 (TRIGGER_PIN2, ECHO_PIN2, MAX_DISTANCE2);// SETUP for 1st ultrasonic sensor
NewPing sonar3 (TRIGGER_PIN3, ECHO_PIN3, MAX_DISTANCE3);
  BackLeft.attach (2); // attach all of the servos to a pin on the board
  BackRight.attach (3);
  FrontRight.attach(4);
  FrontLeft.attach (5);
void loop ()
  delay (50);
  delay (50);
  delay (50);
  if ( CM1 > 1 && CM1 < 20 && LPCOUNT== 5)
     FrontRight.writeMicroseconds (1600);
     FrontLeft.writeMicroseconds (1400);
     delay (500);
     BackLeft.writeMicroseconds (1550);
     BackRight.writeMicroseconds (1550);
     FrontRight.writeMicroseconds (1550);
     FrontLeft.writeMicroseconds (1550);
      unsigned int CM1 = sonar.ping();
      delay (50);
      delay (50);
  delay (50);
    else if ( CM1 > 30 && LPCOUNT == 5)
     BackRight.writeMicroseconds (1600);
        delay (50);
      delay (50);
  delay (50);
     LPCOUNT =7 ;
        delay (50);
          delay (50);
  delay (50);
      else if (CM2 > 30)
        LPCOUNT= 5;
      else if (CM3 > 40)
        LPCOUNT = 5;
      else if (CM2 < 32)
        LPCOUNT= 5;
   else if (CM3 < 30 && CM3 > 2)
     LPCOUNT= 7;
      BackLeft.writeMicroseconds (1400);
        delay (50);
          delay (50);
  delay (50);
     else if (CM2 > 30)
        delay (50);
          delay (50);
  delay (50);
any help would be appreciated
Have you tried printing out the various values to Serial to make sure they are reading what you expect?
http://embeddedsystem1.blogspot.in/search/label/Ping%20Sensor
These three variables
and these three variables:
are not the same variables. How you expect the last three to affect any if statement is a mystery.
Go to File + Preferences, and uncheck the stupid random indent value for tab spacing. It makes your code look stupid.
