Ultrasonic via bluetooth
i'm using processing on a project and i want to have the distance result from ultrasonic sensor via blutooth whenever i press a button , so i made this code on the arduino :
  if(HC05.available())
    c = HC05.read();
  if(c==1)
  cm = dist();
  HC05.write(cm);
float dist()
  long lecture_echo;
  long cm;
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  digitalWrite(trig, LOW);
  lecture_echo = pulseIn(echo, HIGH);
  cm = lecture_echo / 58;
  return cm;
and this in processing :
void keyPressed() {
  if(key == 'Q' || key == 'q')
    port.write(1);
    delay(20);
    dist=port.read();
    println(dist);
but it keep giving me 0 as the distance
Nonsense. The code you post won't even compile.
You REALLY need to learn the difference, on the Arduino side, between print() and write().
Sending a response some random time later does not seem like a good idea.
float dist()
  long lecture_echo;
  long cm;
// Snipped some stuff
  return cm;
Why does the function promise to return a float, but then actually return a long?
The following code may give you distances properly. If so, you could adapt it to your needs and use it along with bluetooth.
#define PIN_HC05_TRIGGER 5
#define PIN_HC05_ECHO 4
#define soundSpeed 341.777 // in meters/sec s = 331.4 + 0.6*Tcelsius (consider this in yor math)
float pingTime; // This variable represents the time required for reaching the target and return
float targetDistance; // This variable represents the distance from the sensor to the target.
pinMode(PIN_HC05_TRIGGER,OUTPUT);
  pinMode(PIN_HC05_ECHO,INPUT);
void loop(){
digitalWrite(PIN_HC05_TRIGGER,LOW);
delayMicroseconds(2000); // pause to set signal
digitalWrite(PIN_HC05_TRIGGER,HIGH);
delayMicroseconds(15); // Pause in High state
 pingTime = pulseIn(PIN_HC05_ECHO,HIGH); //measure the time ping echo pin,  (positive peak)
 pingTime = pingTime/(pow(10,6)); //  converting measured time from microseconds to seconds
 targetDistance = soundSpeed * pingTime; // calculates distance in meters
 targetDistance = targetDistance/2;
 Serial.print("The distance to the target is: ");
 Serial.print(targetDistance);
 Serial.println("meters");
Do not forget to share your improvements.
Regards,
Rezik
