ultrasonic wall detector
I'm making a robot that can sense walls and navigate around them for a project, but am having problems with the code. can anyone give me some advice?
This is my current code:
#include <Servo.h>
const int pingPin = 7;
int pos = 1;
Servo myservo;
Servo myservo2;
myservo.attach(9);
myservo2.attach(8);
long duration, inches, cm;
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
for(pos = 0; pos < 180; cm > 100; pos += 1)
myservo.write(pos);
delay(100);
long microsecondsToInches(long microseconds)
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
If anyone can help, i would greatly appreciate it!
And they are...?
What do you want this to do?
When posting code, please use the # (code) button on the editor's toolbar
#include <Servo.h>
int pos = 1;
Servo myservo;
Servo myservo2;
 myservo.attach(9);
 myservo2.attach(8);
 Serial.print(cm);
 Serial.print("cm");
 delay(100);
   myservo.write(pos);
   delay(100);
it's to check if the position of the motor is 0, less than 180, and the wall is less than 1 m away and then increase the position by 1
Didi you mean:
; pos < 180 && cm > 100;?
You can't just invent arbitrary syntax with C.
ohh, well i'll test and see
Very nice. Works like a charm!
Thanks!
Think of a "for" loop as a "while":
for (; ; <end_loop>) {
<loop_body>
translates to
while () { }
Ok, so now i recently decided, that because servos could only have a maximum rotation of 180 degress, i decided to use a regular hobby motor with the code and replace the servo code with "digitalwrite". i am having problems yet again and am getting the error
"a function-definition is not allowed here before a { token"
On my versions with the servo, they worked (with a little help from the person above), but now they're showing up again.
Can anyone help with this?
oh and this is my new code
int pos = 1;
int eng1 = 13; //sets up motors pins
int eng2 = 12;
 pinMode(eng1, OUTPUT);  // sets motors to output
 pinMode(eng2, OUTPUT);
 pinMode(pingPin, OUTPUT); //sends a pulse
 Serial.print("in, ");// gets the distance in inches and cm
 Serial.print(cm);
 Serial.print("cm");
 delay(100);
 if(cm < 50)
  digitalWrite(eng1, HIGH);   // turn for 1 second
  delay(250);
  digitalWrite(eng1, LOW);    // set the engine off
  digitalWrite(eng2, HIGH);
  digitalWrite(eng1, HIGH);  // run engines
  delay(2000);                  // wait 2 seconds
  digitalWrite(eng2, LOW);
  digitalWrite(eng2, LOW);  // set the engine off
long microsecondsToInches(long microseconds) // error here
} //No, error here
I havent ever seen a error like this before. How do you fix it, anyways?
oh, nvmd. I found the solution. I forgot a second curly brace to end the statement. Thanks for helping me find it.
