Hello, i'm working on a robotics project where I have an HC-SR04 with buzzer (horn) attached to a servo motor where I want to trigger the device when it detects something within its proximity (led light will activate + the horn), as it moves 180 deg back and forth. So far with this code I can only get the servo motor to move 180 deg back and forth but does not trigger the ultrasonic sensor when I put my hand in front of the HC-SR04. I want to try to incorporate both devices to work. I tested both the servo and ultrasonic devices separately beforehand and they both work, here i'm trying to incorporate both devices to correlate together. Could there be a problem with how i'm structuring the program? I made some comments to show what's part of the ultrasonic sensor and servo.
[code]
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
// defines pins numbers
const int trigPin = 9;
const int echoPin = 10;
const int buzzer = 11;
const int ledPin = 13;
// defines variables
long duration;
int distance;
int safetyDistance;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode(buzzer, OUTPUT);
pinMode(ledPin, OUTPUT);
// pin for the servo motor
myservo.attach(8); // attaches the servo on pin 9 to the servo object
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
safetyDistance = distance;
if (safetyDistance <= 5){
digitalWrite(buzzer, HIGH);
digitalWrite(ledPin, HIGH);
else{
digitalWrite(buzzer, LOW);
digitalWrite(ledPin, LOW);
// servo postioning
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
[/code]
