Ultrasonics sensors HC-SR04
Hello,
I have a problem with my two ultrasonics sensors. there are fonctional when I connect one by one but they don't work together, in same time.
My test code :
/* Sensor ultrasonic HC-SR04 */
long lecture_echo1; // 1er sensor
long cm1;
long lecture_echo2; // 2nd sensor
long cm2;
  pinMode(9, INPUT); // 9 = trig US back
  digitalWrite(9, LOW);
  pinMode(8, INPUT); // 8 =  echo US back
  pinMode(12, OUTPUT); // 12 = trig US front
  digitalWrite(12, LOW);
  pinMode(11, INPUT); // 11 = echo US front
  digitalWrite(9, HIGH);
  delayMicroseconds(10);
  lecture_echo1 = pulseIn(8, HIGH);
  cm1 = lecture_echo1 / 58;
  Serial.print("Distance en cm1 : "); // display
  Serial.println(cm1);
  digitalWrite(12, HIGH);
  lecture_echo2 = pulseIn(11, HIGH);
  cm2 = lecture_echo2 / 58;
  Serial.print("Distance en cm2 : ");
  Serial.println(cm2); // display
thanks for your help,
You have defined pin 9 to be input, but are using it as an output.
