ultrasound to pass strings sfrom one arduino to an other ?
my next project has to go 50m (150ft) underwater and transmit 64 character string to an other arduino to the surface. my first guess is to go to ultrasounds while sound works ok underwater. should i go on some kind of modulation ( best guess amplitude ) ? and if yes has anyone some circuit diagram to go on ?
Fifty metres of CAT5 would be simpler.
the problem is that there are no fixed points. so it really has to go wireless . thanks. thanasis
salt water will completely trash CAT5 after a few weeks as the salt diffuses through the insulation and corrodes the wires. The connectors stand no chance. Unless you want it to be a disposable item a proper marine cable would be needed. Fresh water is less aggressive, but still issues!
For ultrasound first identify affordable transducers (hydrophones) I guess. Modulation: many things possible, OOK, FSK, GFSK, QAM, you may have to take the Q of the transducers into account when selecting modulation rate. 50m might be pushing the sensitivity limits with low power transducers. Very high power can be dangerous to living tissue, note.
Can't you just log the data?
MarkT thanks for your response. I have a pair of 25khz receiver/trancemiter and the problem is my knowledge in electronic engineering is none. i have found some diagrams for ultrasound receivers but i don't know if they will do the job here are some of them :
http://1.bp.blogspot.com/_cjfdUPWPfAc/S_LDSDAkcfI/AAAAAAAAAP8/7y1ltyO2ktE/s1600/Ultrasonic+receiver+circuit+Diagram++.jpg
http://4.bp.blogspot.com/_cjfdUPWPfAc/S_LC2QvKljI/AAAAAAAAAP0/cfQqegd0hC8/s1600/ultrasonic+transmitter+circuit+diagram.jpg
https://engineering.purdue.edu/ece477/Webs/F04-Grp08/imgs/tx-rx.jpg
and a 2 pdf files with amplitude modulation
http://www.ece.ucsb.edu/yuegroup/Teaching/ECE2C/Lab/Lab5.pdf ( witch i have a problem with the 2khz sin tone generator ?????????? is it correct ? shouldn't that be 40Khz ?????? )
http://www.ece.ucsb.edu/yuegroup/Teaching/ECE2C/Lab/Lab4.pdf
Are all this going to do the job for me ? should i look for something else ?
thanks in advance Athanasios
florinc i am trying to create an underwater texter, so logging the message won't do the trick. XD thanks any way. I am already over that 2 weeks now and my mind is a mess right now, you never know when a fresh idea is going to come.
Thanks Athanasios
