UM6 Mini Orientation Sensor Zero Gyro
I am using the UM6 gyro with an arduino mega to measure x,y and z angles. Before my pid controller can work, i need to reset the gyro values so the x,y and z angles are all x.
Unfortunately, the datasheet was not super helpful for this and i haven't found anyone else's code to do this.
I have attempted to reset the gyro myself, however the gyro remains the same.
The code i have is below.
Header for gyro config (i.e. zeroing the gyro.)
 #ifndef IMU_Config_h
#define IMU_Config_h
#include <SoftwareSerial.h>
#include "Arduino.h"
#include "IMU_Registers.h"
#include "IMU_Global_Variables.h"
#include "IMU_Packet.h"
// Function to zero out the bias in the Gyros
// Use on startup WHEN THE IMU IS STATIONARY.
// Takes around 3 seconds.
void Zero_Gyros(){
        unsigned char s = 's';
	unsigned char n = 'n';
	unsigned char p = 'p';
        byte pt = (PT_HAS_DATA | PT_ISNT_BATCH);
        byte Address = UM6_ZERO_GYROS;
        byte data = 0x01;
        unsigned int checksum = s+n+p+pt+Address;//+data;
        byte checksum1 = checksum >> 8;
        byte checksum0 = checksum & 0xFF;
        byte pt = (char)(PT_HAS_DATA | PT_ISNT_BATCH);
        byte Address = UM6_MISC_CONFIG;
        byte b3 = 0b00100000;//0x20; //0b00100000;
        byte b2 = 0x00;
        byte b1 = 0x00;
        byte b0 = 0x00;
        //byte data = 0x01;
        unsigned int checksum = s + n + p + pt + Address + b3 + b2 + b1 + b0; //+data;
       while(!Serial1.available()){}
     if(Serial1.available()){
       Serial.print("Serial Available.");
        Serial1.write(s);
        Serial1.write(n);
        Serial1.write(p);
        Serial1.write(pt);
        Serial1.write(Address);
        Serial1.write(b3);
        Serial1.write(b2);
        Serial1.write(b1);
        Serial1.write(b0);
        //Serial1.write(data);
        Serial1.write(checksum1);
        Serial1.write(checksum0);
        // Check if serial is available
         n = Serial1.available();
        // If serial is available, begin reading the output
        if (n > 0){
          // Read the serial from the imu sensor
          c = Serial1.read();
          Serial1.write(c);
          // switch case for the IMU state
            switch(nState){
              // The imu data packet begins with three chars, s, n and p in order
              //   check if these have been recieved.
            case STATE_ZERO : // Begin. Look for 's'.
              // Start of new packet
              //  Delete the old packet data
              Reset();
              if (c == 's'){
                nState = STATE_S;
              }// end if
              else {
                nState = STATE_ZERO;
              }// end else
            case STATE_S : // Have 's'. Look for 'n'.
              if (c == 'n'){
                nState = STATE_SN;
              }// end if
              else {
              }// end else
            case STATE_SN : // Have 'sn'. Look for 'p'.
              if (c == 'p'){
                nState = STATE_SNP;
              }// end if
              else {
              }// end else
              // The data packet header has been recieved
              //    The next output of the IMU is the packet type
            case STATE_SNP : // Have 'snp'. Read PacketType and calculate DataLength.
              UM6_Packet.HasData = 1 && (c & PT_HAS_DATA);
              UM6_Packet.IsBatch = 1 && (c & PT_IS_BATCH);
              UM6_Packet.BatchLength = ((c >> 2) & 0b00001111);
              UM6_Packet.CommFail = 1 && (c & PT_COMM_FAIL);
              nState = STATE_PT;
              if (UM6_Packet.HasData == PT_HASNT_DATA){
                Serial.print("Packet has no data\n");
                if (UM6_Packet.IsBatch == PT_ISNT_BATCH){
                 Serial.print("Packet is not batch\n");
              if (UM6_Packet.CommFail == 1){
                Serial.print("Communication failed\n");
              // Calculate the length of the data selection length (bytes)
              if (UM6_Packet.IsBatch){
                // If the batch flag is set high, the packet length is 4*batch length
                UM6_Packet.DataLength = UM6_Packet.BatchLength * 4;
              }// end if
              else {
                // otherwise the packet length is 4
                UM6_Packet.DataLength = 4;
              }// end else
              // The address of the data is read
              //   This is used to calculate specific outputs
            case STATE_PT : // Have PacketType. Read Address.
              UM6_Packet.Address = c;
              if (UM6_Packet.Address == UM6_ZERO_GYROS){
               Serial.print("Gyro Zero Command Recieved");
              nState = STATE_CHK1;
              //nDataByteCount = 0;
              //nState = STATE_READ_DATA;
              // Read the data from the IMU
            case STATE_READ_DATA : // Read Data. (UM6_PT.BatchLength * 4) bytes.
              aPacketData[nDataByteCount] = c;
              nDataByteCount++;
              if (nDataByteCount >= UM6_Packet.DataLength){
              }// end if
              // Two checksums are sent after the data
            case STATE_CHK1 : // Read Checksum 1
                UM6_Packet.Checksum1 = c;
              nState = STATE_CHK0;
            case STATE_CHK0 : // Read Checksum 0
                UM6_Packet.Checksum0 = c;
              nState = STATE_DONE;
            case STATE_DONE : // Entire packet consumed. Process packet
              //ProcessPacket();
              Serial.print("Packet complete\n");
            }// end switch(nstate)
Any help is greatly appreciated!
When i said the angles all needed to be at x, i meant 0.
Sorry.
