Umlauts tft.println not working
I have an ESP32-TTGO-T4 (BigDisplay) and want use tft.println for printing with umlauts,
but it did not work, can you assist for an example ?
Thank you.
Jenni
Check the character set of the display driver. Umlauts may have non-Unicode codes.
HI @applepi333,
if this page is true
https://github.com/fdufnews/ESP32-TTGO-T4/tree/master
you may use the Adafruit GFX lib.
If this is the case
  • you may have a look at this link
https://forums.adafruit.com/viewtopic.php?t=70719
  • and try this sketch (from the link above, I have not tested it and it may require some adaptation to your application!):
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
// For the Adafruit shield, these are the default.
#define TFT_DC 9
#define TFT_CS 10
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// If using the breakout, change pins as desired
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
  Serial.println("ILI9341 Test!");
  tft.begin();
  tft.fillScreen(ILI9341_BLACK);
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9341_WHITE);  tft.setTextSize(2);
  tft.println("  0123456789ABCDEF");
  for (int row = 0; row < 16; row++)
    tft.print(row,HEX); tft.print(" ");
    for (int col = 0; col < 16; col++)
      char c = row*16 + col;
      if ((c >= '\10') && (c <= '\13')) c = ' '; //don't print LF, VT, FF, CR
      tft.print(c);
    tft.println();
void loop() {}
The sketch should display the entire character set on the ILI9341 ...
Good luck!
