un détecteurs d'éclaire
Bonjour
en attendant la résection d’une commande pour finir un autre projet je me suis lancé dans la réalisation d’un détecteur de flash pour déclencher un appareil photo et pour faire des jolis photos d’orages
je suis donc partie de ce programme
#include <MsTimer2.h>                //MsTimer2 library allows using timer2 interrupts easily and avoids using delay() function
 created June 2015
 modified October 2015
 by Florent Pin
const int triggerPIN=12;                //Digital pin 12 connected to an optocoupler that will trigger the camera shutter
const int prefocusPIN=11;               //Digital pin 11 connected to an optocoupler that will trigger the camera prefocusPINed mode
const int photoTPIN=7;                  //phototransistor connected (with a resistor) to Analog input A0
const int blinkerPIN=9;                //Blinking green led on pin 10 (Power ON LED)
const int SatLedPIN=8;                  //Saturation & triggerPIN indicator (red LED)
int sensorValue = 0;                   //value read from the photoTPINransistor
int prevSensorValue = 0;               //value read from the photoTPINransistor at the previous iteration
int j;
volatile boolean blinker = LOW;        //State of the blinking green LED
  pinMode(triggerPIN,OUTPUT);
  pinMode(prefocusPIN,OUTPUT);
  pinMode(SatLedPIN,OUTPUT);
  pinMode(blinkerPIN,OUTPUT);
  digitalWrite(triggerPIN,LOW);
  digitalWrite(prefocusPIN,HIGH);    //Camera prefocued mode enable permanently
  digitalWrite(SatLedPIN,LOW);
  digitalWrite(blinkerPIN,LOW);
  MsTimer2::set(2000, flash);        //ISR flash launched after 2000ms
  MsTimer2::start();                 //Enable Timer2 interrupts
  sensorValue = analogRead(photoTPIN);                        // read voltage from phototransistor
  if(sensorValue>950){                                        //switch on a red LED if detector is almost saturated
    digitalWrite(SatLedPIN,1);}
  else{
    digitalWrite(SatLedPIN,0);}
  if(sensorValue-prevSensorValue>5){                          //detection threshold
    digitalWrite(SatLedPIN,1);                                //switch on a red LED when the shutter is triggered
    digitalWrite(triggerPIN,HIGH);                            //trigger the camera shutter
    delay(100);
    digitalWrite(SatLedPIN,0);                                //switch off red LEd
  prevSensorValue=sensorValue;                                //save sensor value for comparison with the next measurement
void flash(){                                                //Interrupt Service Routine triggered by Timer2
  blinker= !blinker;                                         //Toggle blinking LED state
  digitalWrite(blinkerPIN,blinker);
  if(blinker){                                               //change next LED state toggle delay for getting  1/100 duty cycle
    MsTimer2::set(20, flash);
    MsTimer2::start();
  else{
    MsTimer2::start();
au quelle j’ai retiré certaine ligne que je trouvais inutile pour mon utilisation
ce qui ma donné ce programme
 created June 2015
 by Florent Pin
const int photoTPIN=7;                  //phototransistor connected (with a resistor) to Analog input A7
const int SatLedPIN=7;                  //Saturation & triggerPIN indicator (red LED)
int j;
  else{
    delay(100);
mais le programme n’est pas encore accès rapide
j’entend par la qu’il déclenche l’optocoupler un peut trop tard du coup je n’ai pas forcément l’éclaire sur ma photo
pour l’améliorer je pensais intégré une boucle while
mais je sais pas trop
qu’en pensez vous ?
cordialement
alexis
Hello
tu fais tes tests avec un flash photo ?
un éclair est beaucoup plus long qu'un flash.
tes tests sont faussés.
oui j'ai fait mes test avec un flash d'appareil photo je suis d'accord qu'un flash est beaucoup plus rapide mais je pense que l'on peut optimisé encore le programme pour qu'il soit encore plus rapide
Je ne comprends pas le fonctionnement de ton code donc je peux difficilement t'aider. Quel est le principe ? À quoi correspond satled ?
Pour ce que je comprends, le code mesure le niveau donné par une photodiode. Si le niveau est supérieur à un seuil de 950 il allume cette satled... C'est quoi ? Le seuil de 950 est choisi comment ? Une valeur plus basse donnerait elle un meilleur résultat ?
Ensuite, si le niveau de la photodiode a augmenté de 5 par rapport au niveau précédemment mesuré, il déclenche le trigger. Pourquoi 5 et pourquoi ce délai de 100 ms ? Un délai plus court est il possible ?
Enfin as tu cherché sur internet ou sur le forum d'autres projets de ce genre ? Ça doit déjà exister à mon humble avis et peut être être déjà optimisé...
hello le sept
je suppose qu’il manque un potar pour régler un seuil par rapport à la lumière ambiante.
seuil qu’ils ont probablement baptisé “de saturation”
Oui, mais comme je n'y connais rien en photographie...
Par contre j'ai trouvé ce lien qui explique comment jouer avec les options de compilation pour optimiser en vitesse.
Une autre solution serait d'utiliser un processeur plus rapide, grâce à un esp8266 ou un esp32
lesept
le principe est que si un grand écart de tension a lieu a l'enté analogique l'appareil photo est déclencher
satled est la led de saturation elle sallume quand l'entré analogique dépasse 950 (valeur un peut aléatoire on pourrait mettre moins) et aussi quand l'appareil est déclencher
pourquoi 5 c'est une bonne question :D moi même je ne sais pas
ensuite le délai c'est pour être sur que l'appareil soit bien déclencher
et justement ce programme ne viens pas de moi je l'ai juste simplifier (site d'origine : http://foudre.chasseurs-orages.com/viewtopic.php?t=6243 )
normalement les déclencheur d'appareil photo ne sont pas basé sur l'arduino pour évité que le traitement des information prenne trop de temps
j'ai oublié de précisé le programme sera envoyer sur un arduino pro mini 16 MGz
Ok Il y a peut être un peu à gagner du côté de cette led de saturation. Tu l'allumes si le niveau est supérieur au seuil et tu la rallumes si le niveau augmente. Je pense que ce n'est pas nécessaire de le faire une seconde fois. Tu peux supposer que l'appareil se déclenche lorsque la luminosité est assez forte à cause de la détection de l'éclair,donc que le led est delà allumée.
Je crois que l'esp32 a une horloge qui tourne à 80 MHz
lesept: Je crois que l'esp32 a une horloge qui tourne à 80 MHz
Ou 160 suivant comment tu le configures.
Par contre, c'est étonnant de passé par le convertisseur AN : pourquoi ne pas le faire en analogique et arrivé avec un signal tout ou rien, ca n'irait pas plus vite ?
Et comment on le configure en 80 ou en 160 ?
Ca se passe par la fonction du sdk nommée system_update_cpu_freq()
