Unable to acess SERVER without USB Cable Connected
I am unable to access the web server unless I plugin the the USB Cable . The USB cable wants to be connected to any USB port. Ir-respective weather the drivers are installed or not.As long as the USB is plugged in I can access the server.
I power the board using a 9V DC transformer and the RJ45 hooks to the Ethernet shield
The board controls a relay.Weather or not the USB cable is plugged in the Relay operation is as per logic
#include <SPI.h>
#include <Ethernet.h>
byte mac = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; //MAC ADDRESS
IPAddress ip(192, 168, 1, 177); //STATIC LAN IP ADDRESS
EthernetServer server(1410); //----->>SERVER PORT<<--------
pinMode(7,OUTPUT);
pinMode(6,INPUT);
pinMode(13,OUTPUT);
Ethernet.begin(mac, ip);
server.begin();
if (client)
if(Serial) Serial.println(“Ethernet Connected”);
**some html… some functions & reading of pins all are working alright and some logic… **
So, as long as the Arduino is getting sufficient power, everything works. Without the power from the USB cable, stuff doesn't work. Well, hello, that looks like a clue.
But what color is it? The important thing is the amperage!
The 9V DC supply is rated at 500ma ... doesn't look like the trouble... or could it be
For a shield that can draw 2A? Nah, that can't be the problem.
;D
I measured the Voltage on the Power supply under load... 4.5Veeee ... :D naah.. The power supply wasnt the problem ;)
PaulS ... Cheers....
So, what was?
:) :) The Ethernet shield was... It was drawing too much power... :smiling_imp:
