Hi, Ive tried many times but cant get it to associate with the cloud. The rp2040 device is detected, I select the device then it fails as the screen says it may take a few minutes.
I have tried several machines. I'm not a noob. This is frustrating. My first experience with the arduino cloud is trash. Is this board not really supported?
Hi Dozie. I have tried all these things.
I am able to flash the board with the 1.81 ide. However I am unable to get the create agent to flash it. I never make it to where I can setup the wireless connection. It sees it initially but then errors out. Please advise.
I've tried this with 2 different, brand-new boards, on 2 separate computers.
Can upload and run sketches with the dedicated IDE, no problems.
I've updated the NINA firmware on the boards with no issues.
-I've had no problem setting up a device using a MKR 1010 WIFI board, so this implies the create agent if installed and running correctly.
This issue seems to be unique to the Nano RP2040 Connect. It fails every time.
There is a test setup called "Cloud Blink" that I ended up using to ensure the board was working properly in the Arduino Cloud. Under IoT Cloud, select the TEMPLATES tab and you'll see Cloud Blink. I was able to make that work after a similar experience. I've since had many sketches running very well and reliably in the cloud. If memory serves me, I first loaded the sketch I made into the 2040 with the USB port and THEN initiated the cloud selection. Give that a go and report back !
So I was able to get my RP2040 Connect recognized by updating the NINA firmware, however, I had to follow method #3 and used the firmware uploader command line tool.
I had initially tried this using method 2, which appeared to succeed yet still did not fix the problem.
Using method 3, the exact command line I used was:
arduino-fwuploader firmware flash -b arduino:mbed_nano:nanorp2040connect -a COM7 -m NINA@1.4.8
After running this, I was able to add and configure the board as an IoT device.
