Unable to break out of loop shown in code below, have tried "do-while" also but in each case I can not break the loop
Any and all suggestions/comments welcomed.
#include "IRremote.h"
#include "FastLED.h"
#define NUM_LEDS 150
#define DATA_PIN 6
CRGB leds[NUM_LEDS];
#define PIN 6
int direction=1;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(150, PIN, NEO_GRB + NEO_KHZ800);
int r =0;
int x = 47;
int d = 2;
int b=75;
int pos = 0, dir = 1;
int j;
int receiver = 3; // pin 1 of IR receiver to Arduino digital pin 11
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
void setup() /----( SETUP: RUNS ONCE )----/
Serial.println("IR Receiver Raw Data + Button Decode Test");
irrecv.enableIRIn(); // Start the receiver
strip.begin();
strip.show();
}/--(end setup )---/
void loop() /----( LOOP: RUNS CONSTANTLY )----/
if (irrecv.decode(&results)) // have we received an IR signal?
// Serial.println(results.value, HEX); UN Comment to see raw values
translateIR();
irrecv.resume(); // receive the next value
}/* --(end main loop )-- */
void translateIR() // takes action based on IR code received
// describing Car MP3 IR codes
switch(results.value)
case 0xFFA25D:
Serial.println(" CH- ");
case 0xFF629D:
Serial.println(" CH ");
case 0xFFE21D:
Serial.println(" CH+ ");
case 0xFF22DD:
Serial.println(" PREV ");
case 0xFF02FD:
Serial.println(" NEXT ");
case 0xFFC23D:
Serial.println(" PLAY/PAUSE ");
case 0xFFE01F:
Serial.println(" VOL- ");
case 0xFFA857:
Serial.println(" VOL+ ");
case 0xFF906F:
Serial.println(" EQ ");
case 0xFF6897:
Serial.println(" 0 ");
case 0xFF9867:
Serial.println(" 100+ ");
case 0xFFB04F:
Serial.println(" 200+ ");
case 0xFF30CF:
Serial.println(" 1 ");
case 0xFF18E7:
Serial.println(" 2 ");
case 0xFF7A85:
Serial.println("Larson Shades code");
do
larsonscannershades();
while ((results.value) == 0xFF7A85);
if ((results.value) == 0xFF7A85)
while( 1 )
case 0xFF10EF:
Serial.println(" 4 ");
case 0xFF38C7:
Serial.println(" 5 ");
case 0xFF5AA5:
Serial.println(" 6 ");
case 0xFF42BD:
Serial.println(" 7 ");
case 0xFF4AB5:
Serial.println(" 8 ");
case 0xFF52AD:
Serial.println(" 9 ");
default:
Serial.println(" other button ");
} //END translateIR
/* ( THE END ) */
void larsonscannershades() {
strip.setPixelColor(pos - 2, 0x111111);
strip.setPixelColor(pos - 1, 0X444444);
strip.setPixelColor(pos , 0xFFFFFF);
strip.setPixelColor(pos + 1, 0x444444);
strip.setPixelColor(pos + 2, 0x111111);
strip.show();
delay(1);
for(j=-2; j<= 2; j++)
strip.setPixelColor(pos+j, 0);
pos += dir;
if(pos < 0)
pos = 1;
dir = -dir;
if(pos >= strip.numPixels())
pos = strip.numPixels() - 2;
dir = -dir;
