Unable to burn bootloader using Arduino as ISP
I'm having alot of problems burning the Arduino bootloader on a ATMega328p MCU.
I'm using Arduino as MCU and following the https://www.arduino.cc/en/tutorial/arduinoISP.
Using ArduinoISP i got Can't find programmer id "arduinoisp"
And using Arduino as ISP i got:
Arduino: 1.8.8 (Linux), Board: "Arduino/Genuino Uno"
//bin/avrdude -C//etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyACM2 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Jan 11 2019 at 08:12:38
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "//etc/avrdude.conf"
         User configuration file is "/home/artur/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM2
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
         Hardware Version: 971338560
         Firmware Version: 19200.0
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done.  Thank you.
Error while burning bootloader.
I dont really know the difference between those options. But it seems that avrdude doesn't have the config for ArduinoISP so it seems that Arduino as ISP is the right choice?
I tried all the reset options, 10k resistor, nothing, 10uf capactor, both. Same result.
I've replaced all the cables and checked if the power is getting into the target using a LED.
I have also tested with another atmega328p that i already have the bootloader and a blink sketch, just to test, and the mega is running (led is bliking away) but i cannot burn the bootloader.
Here a pic of my breadboard.
Well... I need to run this mega as 20MHz for timming purposes, i was looking at MiniCore to that answer, but i cant even burn a regular bootloader into the chip. The thing is that i've done this before without problem.
I'm running Arduino 1.8.8 from Arch Linux repositories and i've also installed Arduino AVR Boards 1.6.23 from the board manager (looks like a requisite for MiniCore).
(deleted)
Thank you.
Do you have any material that explain the difference? I couldn't find anything explaining any of those options on the internet.
Also, the ArduinoISP "looks like was wrong" from the error, so all my testing was done using Arduino as ISP since it "looks the right one".
ArduinoISP is this programmer Accessories — Arduino Official Store
