I am trying to implement CoAP by communicating with ESP8266 using the same. I am using below code:
ESP-COAP Client
#include <ESP8266WiFi.h>
#include "coap_client.h"
//instance for coapclient
coapClient coap;
//WiFi connection info
const char* ssid = "xxxxxxxxxxxxx";
const char* password = "xxxxxxxxxxx" ;
//ip address and default port of coap server in which your interested in
IPAddress ip(129,132,15,80);//take ETH Zurich or coap.me server to run and check client
int port =5683;
// coap client response callback
void callback_response(coapPacket &packet, IPAddress ip, int port);
void callback_response(coapPacket &packet, IPAddress ip, int port) {
char p[packet.payloadlen + 1];
memcpy(p, packet.payload, packet.payloadlen);
p[packet.payloadlen] = NULL;
//response from coap server
if(packet.type==3 && packet.code==0){
Serial.println("ping ok");
Serial.println(p);
WiFi.begin(ssid, password);
Serial.println(" ");
// Connection info to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
//delay(500);
yield();
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Print the IP address of client
// client response callback.
// this endpoint is single callback.
coap.response(callback_response);
// start coap client
coap.start();
//get request to server (arguments ip adrress of server,default port,resource(uri))
int msgid = coap.get(ip,port,"light");
//observe request (arguments ip adrress of server,deafult port,resource name,interger(0) )
//int msgid= coap.observe(ip,port,"light",0);
//reset observe cancel
//int msgid=coap.observecancel(ip,port,"resoucename");
//int i=0;
bool state;
// Requests
//get request
//int msgid = coap.get(ip,port,"hello");
//put request
//arguments server ip address,default port,resource name, payload,payloadlength
//int msgid =coap.put(ip,port,"resourcename","0",strlen("0"));
//post request
//int msgid =coap.post(ip,port,"resourcename","0",strlen("0"));
//delete request
//int msgid = coap.delet(ip,port,"resourcename");
//ping
//int msgid=coap.ping(ip,port);
// int msgid=coap.observe(ip,port,"obs",0);
state= coap.loop();
// Serial.print("state=");
//Serial.println(state);
//if(state==true)
//i=i+1;
//Serial.print("i=");
//Serial.println(i);
//if(i==3)
//Serial.println("cancel observe");
//coap.observeCancel(ip,port,"resourcename");
//Serial.println(msgid);
I am able to upload sketch successfully to ESP8266 and I recieve message as "172.16121.49" in serial
monitor where as in code the ip address mentioned is (129,132,15,80). I have tried to use coap.me server to crawl CoAP server on both above mentioned ip addresses but it tries four times and then times out.
I have used the above code from the below mentioned url:
ESP-CoAP arduino sketch
Can anyone help me to solve the problem?
