Iam trying to write data from one esp32-wroom-32 controller to other esp32-wroom-32controller using modbus protocal via rs485 ttl converter ,but iam facing error like unable to make communication, getting 226 error message i tried with pooling method also same issue iam facing
please help me with this ,iam little bit new to this protocal sorry if i make any mistake in this writing message
if anyone have some example codes to test please reply or send me i dont know y my code is not working please help me with this
i have used uart0 pins: gpio-3(RX) and gpio-1(TX) or
uart 2 pins: gpio-16(RX) and gpio 17(TX), and DE and RE pins connected to gpio 4.
The board iam selected esp32-dev module and also tried with esp32-wrrom dev module
issues:-iam unable to write data its getting error(226) fail to write data in receive also same message read fail 226 error
Thank you in advance
***This is my Slave code:***
#include <ModbusMaster.h>
// Instantiate ModbusMaster object
ModbusMaster node;
// Define the slave ID
const uint8_t SLAVE_ID = 1;
// Define GPIO pin for controlling DE and RE
const int DE_RE_PIN = 4;
Serial.begin(9600, SERIAL_8O1);
// Serial.begin(9600); // Set baud-rate to 9600 for debugging
// Serial1.begin(9600, SERIAL_8E1); // Initialize Serial1 for Modbus communication
node.begin(SLAVE_ID, Serial); // Begin Modbus communication with Serial1
pinMode(DE_RE_PIN, OUTPUT); // Set DE/RE pin as output
// Initially set DE/RE pin to LOW (Receive mode)
digitalWrite(DE_RE_PIN, HIGH);
//uint16_t dataToSend = 12; // Data to be sent
// Enable transmission by setting DE/RE pin to HIGH
// digitalWrite(DE_RE_PIN, HIGH);
// Write the data to a single holding register at address 10
uint8_t result = node.writeSingleRegister(0x0000, 2);
// Disable transmission by setting DE/RE pin to LOW
// digitalWrite(DE_RE_PIN, LOW);
// Check if the write was successful
if (result == node.ku8MBSuccess) {
Serial.println("Data sent successfully");
Serial.print("Failed to send data. Error code: ");
Serial.println(result);
***This is my master code:***
// Define the GPIO pin for DE/RE (using pin 4)
ModbusMaster node;
void preTransmission() {
digitalWrite(DE_RE_PIN, HIGH); // Enable transmission mode
void postTransmission() {
digitalWrite(DE_RE_PIN, LOW); // Enable receive mode
// Start serial communication
// Initialize Modbus communication
node.begin(SLAVE_ID, Serial1);
// Set up callbacks to handle transmission
// node.preTransmission(preTransmission);
//node.postTransmission(postTransmission);
// Read data from holding register
uint8_t result = node.readHoldingRegisters(0x8A, 1);
// Check if the read was successful
// Print received data
Serial.print("Received data: ");
Serial.println(node.getResponseBuffer(0));
// Print error if read failed
Serial.print("Failed to read data. Error code: ");
Serial.println(result,HEX);
