Unable to compile Arduino GSM Shield 2 (Verbose) ???
Hello Evryone,
I am using Arduino version 1.6.6 with the Arduino Uno and the Arduino GSM Shield 2. When I try to compile the GSM SendSMS example, I get this Error: (verbose below):
Arduino: 1.6.6 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from C:\Program Files (x86)\Arduino\libraries\GSM\src/GSM.h:46:0,
                 from C:\Program Files (x86)\Arduino\libraries\GSM\examples\SendSMS\SendSMS.ino:25:
C:\Program Files (x86)\Arduino\libraries\GSM\src/GSM3ShieldV1BandManagement.h:49:125: warning: 'typedef' was ignored in this declaration [enabled by default]
 typedef enum GSM3GSMBand {UNDEFINED, EGSM_MODE, DCS_MODE, PCS_MODE, EGSM_DCS_MODE, GSM850_PCS_MODE, GSM850_EGSM_DCS_PCS_MODE};
C:\Program Files (x86)\Arduino\libraries\GSM\examples\SendSMS\SendSMS.ino: In function 'void setup()':
C:\Program Files (x86)\Arduino\libraries\GSM\examples\SendSMS\SendSMS.ino:48:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3MobileMockupProvider.cpp: In constructor 'GSM3MobileMockupProvider::GSM3MobileMockupProvider()':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3MobileMockupProvider.cpp:44:12: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  msgExample="Hello#World";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3MobileMockupProvider.cpp: In member function 'int GSM3MobileMockupProvider::connectTCPServer(int, char*, int*)':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3MobileMockupProvider.cpp:183:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   strcpy("192.168.1.1", localIP);
In file included from C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:34:0:
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp: In constructor 'GSM3ShieldV1BandManagement::GSM3ShieldV1BandManagement(bool)':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:38:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  quectelStrings[UNDEFINED]="";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:39:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  quectelStrings[EGSM_MODE]="\"EGSM_MODE\"";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:40:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  quectelStrings[DCS_MODE]="\"DCS_MODE\"";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:41:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  quectelStrings[PCS_MODE]="\"PCS_MODE\"";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:42:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  quectelStrings[EGSM_DCS_MODE]="\"EGSM_DCS_MODE\"";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:43:33: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  quectelStrings[GSM850_PCS_MODE]="\"GSM850_PCS_MODE\"";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1BandManagement.cpp:44:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  quectelStrings[GSM850_EGSM_DCS_PCS_MODE]="\"GSM850_EGSM_DCS_PCS_MODE\"";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1ModemCore.cpp:39:14: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
 char* __ok__="OK";
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1ModemVerification.cpp: In member function 'String GSM3ShieldV1ModemVerification::getIMEI()':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1ModemVerification.cpp:64:20: warning: passing NULL to non-pointer argument 1 of 'String::String(int, unsigned char)' [-Wconversion-null]
  String number(NULL);
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1SMSProvider.cpp: In member function 'void GSM3ShieldV1SMSProvider::beginSMSContinue()':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1SMSProvider.cpp:68:57: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   if(theGSM3ShieldV1ModemCore.genericParse_rsp(resp, ">"))
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1ScanNetworks.cpp: In member function 'String GSM3ShieldV1ScanNetworks::getCurrentCarrier()':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1ScanNetworks.cpp:66:21: warning: passing NULL to non-pointer argument 1 of 'String::String(int, unsigned char)' [-Wconversion-null]
   return String(NULL);
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1ScanNetworks.cpp: In member function 'String GSM3ShieldV1ScanNetworks::getSignalStrength()':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3ShieldV1ScanNetworks.cpp:85:21: warning: passing NULL to non-pointer argument 1 of 'String::String(int, unsigned char)' [-Wconversion-null]
In file included from C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3SoftSerial.cpp:38:0:
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3SoftSerial.cpp: In member function 'int GSM3SoftSerial::begin(long int)':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3SoftSerial.cpp:167:27: error: '__RXPIN__' was not declared in this scope
     if (digitalPinToPCICR(__RXPIN__))
C:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard/pins_arduino.h:56:36: note: in definition of macro 'digitalPinToPCICR'
 #define digitalPinToPCICR(p)    (((p) >= 0 && (p) <= 21) ? (&PCICR) : ((uint8_t *)0))
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3SoftSerial.cpp: In member function 'void GSM3SoftSerial::setTX()':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3SoftSerial.cpp:263:11: error: '__TXPIN__' was not declared in this scope
   pinMode(__TXPIN__, OUTPUT);
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3SoftSerial.cpp: In member function 'void GSM3SoftSerial::setRX()':
C:\Program Files (x86)\Arduino\libraries\GSM\src\GSM3SoftSerial.cpp:273:11: error: '__RXPIN__' was not declared in this scope
   pinMode(__RXPIN__, INPUT);
exit status 1
Error compiling.
  enabled in File > Preferences.
May I need to change something in the Library?
Any Idea about this issue???.
Thank you Guys!
Foks
Hi Evrybody, (RESOLVED)
I resolved the Problem. I updated my Arduino DIE version to the 1.7.1, compiled and uploaded the SendSMS example successfully on the Boards.
Great !!! It works very well. I just leaved blank the field for the PINNUMBER , then it works. Even if the SIM has a PINNUMBER, leave it blank.
Great thing. :slight_smile: :slight_smile: :slight_smile:
