unable to compile OLED_inverse_dislplay
Hi - I am using an arduino 101 with a seeed board. When I try to verify OLED_inverse_display code it gives the error below. I saw some similar posts but need some help to exactly understand how to solve? Do I need to add another library or edit an existing lib?
thanks!
/home/ubuntu/opt/libraries/latest/grove_oled_display_0_96_1_0_0/SeeedOLED.cpp:31:22: fatal error: pgmspace.h: No such file or directory
#include <pgmspace.h>
compilation terminated.
exit status 1
You could edit the existing library if you like but I have made a fork of the library with this error fixed for the 101 that you can download here: https://github.com/per1234/OLED_Display_128X64/archive/support-101.zip
If you import that to the Arduino Web Editor it should fix the problem.
I have submitted a pull request for this fix to the original library: https://github.com/Seeed-Studio/OLED_Display_128X64/pull/9
I don't own the hardware to test this fix out so please let me know if my version of the library gets the display working on your 101.
