Hey All,
So I am trying to compile a sketch for the Adafruit feather M4 express, and I am using an RFM9x LoRa module. Compiling for the M0 is fine, but when I try to compile for the SAMD51 I get compiling errors that I don't get with a ATSAMD21. This makes sense, as looking in the library the issue is in RH_ASK.cpp where it sets up the clock and interrupts for the 48Mhz ATSAMD21.
#elif defined (__arm__) && defined(ARDUINO_ARCH_SAMD)
// Arduino Zero
#define RH_ASK_ZERO_TIMER TC3
// Clock speed is 48MHz, prescaler of 64 gives a good range of available speeds vs precision
#define RH_ASK_ZERO_PRESCALER 64
#define RH_ASK_ZERO_TIMER_IRQ TC3_IRQn
// Enable clock for TC
REG_GCLK_CLKCTRL = (uint16_t) (GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN_GCLK0 | GCLK_CLKCTRL_ID(GCM_TCC2_TC3)) ;
while ( GCLK->STATUS.bit.SYNCBUSY == 1 ); // wait for sync
// The type cast must fit with the selected timer mode
TcCount16* TC = (TcCount16*)RH_ASK_ZERO_TIMER; // get timer struct
TC->CTRLA.reg &= ~TC_CTRLA_ENABLE; // Disable TC
while (TC->STATUS.bit.SYNCBUSY == 1); // wait for sync
TC->CTRLA.reg |= TC_CTRLA_MODE_COUNT16; // Set Timer counter Mode to 16 bits
TC->CTRLA.reg |= TC_CTRLA_WAVEGEN_MFRQ; // Set TC as Match Frequency
// Compute the count required to achieve the requested baud (with 8 interrupts per bit)
uint32_t rc = (VARIANT_MCK / _speed) / RH_ASK_ZERO_PRESCALER / 8;
TC->CTRLA.reg |= TC_CTRLA_PRESCALER_DIV64; // Set prescaler to agree with RH_ASK_ZERO_PRESCALER
TC->CC[0].reg = rc; // FIXME
// Interrupts
TC->INTENSET.reg = 0; // disable all interrupts
TC->INTENSET.bit.MC0 = 1; // enable compare match to CC0
// Enable InterruptVector
NVIC_ClearPendingIRQ(RH_ASK_ZERO_TIMER_IRQ);
NVIC_EnableIRQ(RH_ASK_ZERO_TIMER_IRQ);
// Enable TC
TC->CTRLA.reg |= TC_CTRLA_ENABLE;
Does anyone have replacement code so we can iron this issue out? This seems like it may effect others in the future who wish to use LoRa products and the M4 feather, such as the RFM feather wing in the Adafruit store. I will be head bashing towards a newbie solution until someone who knows what they're doing comes along
