I'm unable to load my custom sketch on my m5stick but when I tried with default examples it's working fine, I don't know how to resolve this…
I got this error message:
In file included from C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessmesh/ntp.hpp:16,
from C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessmesh/mesh.hpp:6,
from C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessMeshConnection.h:16,
from C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessMesh.h:20,
from C:\Users\Pradeep\Desktop\sketch_nov04a\sketch_nov04a.ino:1:
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessmesh/router.hpp: In function 'void painlessmesh::router::handleNodeSync(T&, painlessmesh::protocol::NodeTree, std::shared_ptr<_Tp>)':
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessmesh/router.hpp:162:26: warning: lambda capture initializers only available with -std=c++14 or -std=gnu++14
mesh.addTask([&mesh, remoteNodeId = newTree.nodeId]() {
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessmesh/router.hpp:189:26: warning: lambda capture initializers only available with -std=c++14 or -std=gnu++14
mesh.addTask([&mesh, nodeId = newTree.nodeId]() {
In file included from C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/painlessMesh.h:23,
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp: In member function 'void painlessmesh::wifi::Mesh::eventHandleInit()':
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:252:22: error: 'SYSTEM_EVENT_SCAN_DONE' is not a member of 'arduino_event_id_t'
WiFiEvent_t::SYSTEM_EVENT_SCAN_DONE);
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:261:22: error: 'SYSTEM_EVENT_STA_START' is not a member of 'arduino_event_id_t'
WiFiEvent_t::SYSTEM_EVENT_STA_START);
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:272:22: error: 'SYSTEM_EVENT_STA_DISCONNECTED' is not a member of 'arduino_event_id_t'
WiFiEvent_t::SYSTEM_EVENT_STA_DISCONNECTED);
C:\Users\Pradeep\Documents\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:282:22: error: 'SYSTEM_EVENT_STA_GOT_IP' is not a member of 'arduino_event_id_t'
WiFiEvent_t::SYSTEM_EVENT_STA_GOT_IP);
exit status 1
Error compiling for board M5Stick-C. >
This sketch was actually worked with win10 , but now I'm got this error with win8.1 OS.
#include "painlessMesh.h"
#include <WiFi.h>
#define MESH_PREFIX "whateverYouLike"
#define MESH_PASSWORD "somethingSneaky"
#define MESH_PORT 5555
// Replace with your network credentials
const char* ssid = "ESP32-Access-Point";
const char* password = "123456789";
Scheduler userScheduler; // to control your personal task
painlessMesh mesh;
// User stub
void sendMessage() ; // Prototype so PlatformIO doesn't complain
Task taskSendMessage( TASK_SECOND * 1 , TASK_FOREVER, &sendMessage );
void sendMessage() {
String msg = "Hello from node ";
msg += mesh.getNodeId();
mesh.sendBroadcast( msg );
taskSendMessage.setInterval( random( TASK_SECOND * 1, TASK_SECOND * 5 ));
// Needed for painless library
void receivedCallback( uint32_t from, String &msg ) {
Serial.printf("startHere: Received from %u msg=%s\n", from, msg.c_str());
void newConnectionCallback(uint32_t nodeId) {
Serial.printf("--> startHere: New Connection, nodeId = %u\n", nodeId);
void changedConnectionCallback() {
Serial.printf("Changed connections\n");
void nodeTimeAdjustedCallback(int32_t offset) {
Serial.printf("Adjusted time %u. Offset = %d\n", mesh.getNodeTime(),offset);
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
mesh.setDebugMsgTypes( ERROR | STARTUP ); // set before init() so that you can see startup messages
mesh.init( MESH_PREFIX, MESH_PASSWORD, &userScheduler, MESH_PORT );
mesh.onReceive(&receivedCallback);
mesh.onNewConnection(&newConnectionCallback);
mesh.onChangedConnections(&changedConnectionCallback);
mesh.onNodeTimeAdjusted(&nodeTimeAdjustedCallback);
userScheduler.addTask( taskSendMessage );
taskSendMessage.enable();
// Connect to Wi-Fi network with SSID and password
Serial.print("Setting AP (Access Point)…");
// Remove the password parameter, if you want the AP (Access Point) to be open
WiFi.softAP(ssid, password);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
if (currentLine.length() == 0) {
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
//client.println(".button { background-color: #4CAF50; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #555555;}</style></head>");
// Web Page Heading
client.println("<body><h1>ESP32 Web Server</h1>");
client.println("</body></html>");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
and the error message ....
In file included from C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessmesh/ntp.hpp:16,
from C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessmesh/mesh.hpp:6,
from C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessMeshConnection.h:16,
from C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessMesh.h:20,
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessmesh/router.hpp: In function 'void painlessmesh::router::handleNodeSync(T&, painlessmesh::protocol::NodeTree, std::shared_ptr<_Tp>)':
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessmesh/router.hpp:162:26: warning: lambda capture initializers only available with -std=c++14 or -std=gnu++14
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessmesh/router.hpp:189:26: warning: lambda capture initializers only available with -std=c++14 or -std=gnu++14
In file included from C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/painlessMesh.h:23,
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp: In member function 'void painlessmesh::wifi::Mesh::eventHandleInit()':
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:252:22: error: 'SYSTEM_EVENT_SCAN_DONE' is not a member of 'arduino_event_id_t'
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:261:22: error: 'SYSTEM_EVENT_STA_START' is not a member of 'arduino_event_id_t'
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:272:22: error: 'SYSTEM_EVENT_STA_DISCONNECTED' is not a member of 'arduino_event_id_t'
C:\Program Files (x86)\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:282:22: error: 'SYSTEM_EVENT_STA_GOT_IP' is not a member of 'arduino_event_id_t'
exit status 1
