Trying to connect redboard to RFID so it can serve as a proximity sensor. Getting the vague "error compiling for board arduino/genuino uno" error with no other message and not sure where the problem is, any help would be much appreciated Currently the main issue is we are unable to find out where the output info is located.
* function:get the id of RFID key
* RFID SunFounder Uno
* VCC 3.3V
* RST 2
* GND GND
* MISO 3
* MOSI 4
* SCK 5
* NSS 6
* IRQ 7
#include"rfid1.h"
RFID1 rfid;//create a variable type of RFID1
uchar serNum[5]; // array to store your ID
Serial.begin(9600); //initialize the serial
rfid.begin(7, 5, 4, 3, 6, 2); ////rfid.begin(IRQ_PIN,SCK_PIN,MOSI_PIN,MISO_PIN,NSS_PIN,RST_PIN)
delay(100);//delay 1s
rfid.init(); //initialize the RFID
uchar status;
uchar str[MAX_LEN];
// Search card, return card types
status = rfid.request(PICC_REQIDL, str);
if (status != MI_OK)
return;
// Show card type
rfid.showCardType(str);
//Prevent conflict, return the 4 bytes Serial number of the card
status = rfid.anticoll(str);
if (status == MI_OK)
Serial.print("The card's number is: ");
memcpy(serNum, str, 5);
rfid.showCardID(serNum);//show the card ID
rfid.halt(); //command the card into sleep mode
The code was taken from an online guide for a similar project but we cannot quite get it to work. We are unsure where the requested info is being printed to.
If any additional info is needed for a solution I will gladly provide whatever else might be required. Thank you!
