unable to connect in ap-mode in esp32
hello,
I am making and auto connect code for esp32 in which i am trying to get wifi credential from the webpage when it is operated in ap-mode after getting credential it will connected to wifi whose credential are provided in webpage. But problem i am facing is that i am unable to connect my esp module when it is in ap mode here is my code
https://www.codepile.net/pile/MaVLoGR8
//#include <ESP8266WiFi.h>
//#include <ESP8266WebServer.h>
#include "SPIFFS.h"
#include <FS.h>
#include <ArduinoJson.h>
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
//ESP8266WebServer server;
uint8_t pin_led = 2;
char* ssid = "YOUR_SSID"; //not used
char* password = "YOUR_AP_PASSWORD";
char* mySsid = "YOUR_AP_SSID";
AsyncWebServer server(80);
IPAddress local_ip(192,168,11,4);
IPAddress gateway(192,168,11,1);
IPAddress netmask(255,255,255,0);
char webpage[] PROGMEM = R"=====(
<html>
<head>
</head>
<body>
  <form>
    <fieldset>
      <div>
        <label for="ssid">SSID</label>
        <input value="" id="ssid" placeholder="SSID">
      </div>
      <div>
        <label for="password">PASSWORD</label>
        <input type="password" value="" id="password" placeholder="PASSWORD">
      </div>
      <div>
        <button class="primary" id="savebtn" type="button" onclick="myFunction()">SAVE</button>
      </div>
    </fieldset>
  </form>
</body>
<script>
function myFunction()
  console.log("button was clicked!");
  var ssid = document.getElementById("ssid").value;
  var password = document.getElementById("password").value;
  var data = {ssid:ssid, password:password};
  var xhr = new XMLHttpRequest();
  var url = "/settings";
  xhr.onreadystatechange = function() {
    if (this.readyState == 4 && this.status == 200) {
      // Typical action to be performed when the document is ready:
      if(xhr.responseText != null){
        console.log(xhr.responseText);
  xhr.open("POST", url, true);
  xhr.send(JSON.stringify(data));
</script>
</html>
  pinMode(pin_led, OUTPUT);
  SPIFFS.begin();
  wifiConnect();
server.on("/", HTTP_POST, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", webpage);
  server.on("/toggle", HTTP_POST, [](AsyncWebServerRequest *request){
    digitalWrite(pin_led,!digitalRead(pin_led));
    request->send(204,"");
  server.on("/settings", HTTP_POST, [](AsyncWebServerRequest *request){
    if(request->hasArg("plain")){
  String data = request->arg("plain");//("plain");
  DynamicJsonDocument doc(1024);
  serializeJson(doc, data);
 // DynamicJsonBuffer jBuffer;
  //JsonObject jObject = doc.as<JsonObject>();
  File configFile = SPIFFS.open("/config.json", "w");
  serializeJsonPretty(doc, configFile);
  //jObject.printTo(configFile);
  configFile.close();
  request->send(200, "application/json", "{\"status\" : \"ok\"}");
  wifiConnect();
  //server.on("/",[](){server.send_P(200,"text/html", webpage);});
  //server.on("/toggle",toggleLED);
 // server.on("/settings", HTTP_POST, handleSettingsUpdate);
  server.begin();
void wifiConnect()
  //reset networking
  WiFi.softAPdisconnect(true);
  WiFi.disconnect();
  //check for stored credentials
  if(SPIFFS.exists("/config.json")){
    const char * _ssid = "", *_pass = "";
    File configFile = SPIFFS.open("/config.json", "r");
    if(configFile){
      size_t size = configFile.size();
      std::unique_ptr<char[]> buf(new char[size]);
      configFile.readBytes(buf.get(), size);
      configFile.close();
     // DynamicJsonBuffer jsonBuffer;
       DeserializationError error=deserializeJson(doc, buf.get());
     //JsonObject& jObject = doc.as<JsonObject>();
     if (error)
    Serial.print("deserializeJson() failed: ");
    Serial.println(error.c_str());
     else{
        _ssid = doc["ssid"];
        _pass = doc["password"];
        WiFi.mode(WIFI_STA);
        WiFi.begin(_ssid, _pass);
        unsigned long startTime = millis();
        while (WiFi.status() != WL_CONNECTED)
          Serial.print(".");
          if ((unsigned long)(millis() - startTime) >= 5000) break;
  if (WiFi.status() == WL_CONNECTED)
    digitalWrite(pin_led,HIGH);
  } else
    WiFi.mode(WIFI_AP);
    WiFi.softAPConfig(local_ip, gateway, netmask);
    WiFi.softAP(mySsid, password);
    digitalWrite(pin_led,LOW);
  Serial.println("");
  WiFi.printDiag(Serial);
can anyone help me to figure it out
The site you linked to has a lot of annoying pop ups and such garbage. Please just post the code here, following the forum guidelines on how to do that.
Use code tags. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Also, if you don't do it, some of the character sequences in the code can be misinterpred by the forum code as italics or funny emoticons. The "Code: [Select]" feature allows someone to select the entire sketch so it can be easily copied and pasted into the IDE for testing.
