I provided api key, ssid and password. The code compiles and uploads successfully to Wemos Mini (ESP8266). However, when I view output using serial monitor, it goes into an infinite loop which displays text below:
Attempting to connect to WPA SSID: xyz
Status = 1
I am new to this programming environment, so it will be great if you could provide some clarification of what I am doing wrong.
Thanks
Below is my code:
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <WifiLocation.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <SoftwareSerial.h>
/////////////////////////////// Settings /////////////////////////////////////////////
const char* googleApiKey = ""; // Your google geolocation api key
const char* ssid = ""; // Your Wifi SSID
const char* passwd = ""; // Your Wifi Password
const float timeZone = 8;
#define sensorPin A0
//SoftwareSerial MyBlue(2, 3); // RX | TX
// Define Trig and Echo pin:
//#define trigPin 2
//#define echoPin 3
// Define variables:
unsigned long lastTime;
float distance;
boolean low, high, startup = true;
unsigned char alert = 0, event = 0;
String csv;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org");
WifiLocation location(googleApiKey);
location_t loc;
Serial1.begin(9600);
Serial.println("Water Level Detector Started...");
// Connect to WPA/WPA2 network
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, passwd);
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// wait 5 seconds for connection:
Serial.print("Status = ");
Serial.println(WiFi.status());
timeClient.begin();
timeClient.setTimeOffset(timeZone*3600);
pinMode(sensorPin, INPUT);
