I’m attempting to extend and retract a Firgelli FA-OS-400 linear actuator using an ibt-2 motor controller and an Arduino Uno. The product page (Optical Feedback Linear Actuators | Firgelli Automations Canada) claims that this actuator should be compatible wth this controller.
My wiring is as follows:
- 12v battery - and + to the 1st and 2nd terminals on the ibt-2
- motor + and - to 3rd and 4th terminals on the ibt-2
- ibt-2 vcc to arduino 5v
- ibt-2 ground to arduino ground
- ibt-2 R_EN and L_EN to arduino 5v
- ibt-2 R_PWM and L_PWM to arduino pins 5 and 6
My code to control the motors is as follows:
int RPWM_Output = 5;
int LPWM_Output = 6;
int dir = 0;
pinMode(RPWM_Output, OUTPUT);
pinMode(LPWM_Output, OUTPUT);
Serial.setTimeout(100);
if (Serial.available()) {
String ch = Serial.readStringUntil("\n");
if (ch == "a\n") {
dir = -1;
} else if (ch == "b\n") {
dir = 1;
analogWrite(LPWM_Output, 0);
analogWrite(RPWM_Output, 0);
if (dir == -1) {
// reverse rotation
int reversePWM = 255;
analogWrite(RPWM_Output, reversePWM);
else if (dir == 1) {
// forward rotation
int forwardPWM = 50;
analogWrite(LPWM_Output, forwardPWM);
delay(10);
What I would expect this to do is that when “a” is input over serial, the actuator will move in one direction, and when “b” is input, it will move in the reverse direction. Instead, I’m seeing the following behavior:
- Initially, pressing “a” causes the actuator to begin extending as expected.
- If I then press “b”, the actuator will retract.
- However, if I press “a” a second time, the actuator will stop instead of moving upwards, and my multimeter will show 0v going to the motor.
- If I enter “b” again, the actuator will lower, but inputing “a” a second time will just cause it to stop again.
- If I restart the Arduino, the motor will extend once, and then the same issue occurs.
Any ideas on how I can get the actuator to extend more than once, without having to restart every time?
