Unable to detect Atmega2560 for bootloading
Hello,
I have got Atmega2560-AU, I was trying to upload bootloaders into it using Nick Gammons method on the very first time chip detected and showed me output something like this
Atmega chip programmer.
Written by Nick Gammon.
Entered programming mode OK.
Signature = 0x1E 0x98 0x01
Processor = ATmega2560
Flash memory size = 262144 bytes.
LFuse = 0xFF
HFuse = 0xD8
EFuse = 0xFD
Lock byte = 0xCF
Bootloader address = 0x3E000
Bootloader length = 8192 bytes.
Type 'G' to program the chip with the bootloader ...
It also showed in in the end, Type 'Q' for Quit and 'V' for Verify.
I pressed 'G' as i wanted to upload the booatloaders, then it showed me this
Writing bootloader ...
Committing page starting at 0x3E000
Committing page starting at 0x3E100
Committing page starting at 0x3E200
Committing page starting at 0x3E300
Committing page starting at 0x3E400
Committing page starting at 0x3E500
Committing page starting at 0x3E600
Committing page starting at 0x3E700
Committing page starting at 0x3E800
Committing page starting at 0x3E900
Committing page starting at 0x3EA00
Committing page starting at 0x3EB00
Committing page starting at 0x3EC00
Committing page starting at 0x3ED00
Committing page starting at 0x3EE00
Committing page starting at 0x3EF00
Committing page starting at 0x3F000
Committing page starting at 0x3F100
Committing page starting at 0x3F200
Committing page starting at 0x3F300
Committing page starting at 0x3F400
Committing page starting at 0x3F500
Committing page starting at 0x3F600
Committing page starting at 0x3F700
Committing page starting at 0x3F800
Committing page starting at 0x3F900
Committing page starting at 0x3FA00
Committing page starting at 0x3FB00
Committing page starting at 0x3FC00
Committing page starting at 0x3FD00
Committing page starting at 0x3FE00
Committing page starting at 0x3FF00
Written.
Verifying ...
No errors found.
Writing fuses ...
LFuse = 0xFF
HFuse = 0xD8
EFuse = 0xFD
Lock byte = 0xCF
Attempting to enter ICSP programming mode ...
I re-opened the Serial Monitor and now it is showing me only this
Attempting to enter ICSP programming mode ......................................................
I thought the chip is fried, so i went down and bought 2 more chips! But same thing happened to them also.
I am using 16Mhz Crystal with all the correct connections.
NOTE : The quoted content is not exactly same what i got in the serial monitor, I copied them from the Nick website, I don't have the real Logs.
Please help me!
My guess is that the crystal is connected improperly, based on the observation that it apparently successfully writes the flash, writes the fuses, and then the chip is comatose - but this is a guess. It looks like that sketch doesn't output even the minimal level of debugging output that you get when using avrdude for that.
Got an ISP programmer you can hook up to it and confirm that it's reading out the signature as 0x000000?
Check crystal connections with an ohm meter - check for short to eachother, short to ground, short to Vcc, and doublecheck that you have the right caps too (20pf for most crystals, but check the specs for the crystal to be sure)
Hello @DrAzzy , I checked the connections with the Crystal and Your guess is correct :slight_smile: Thank you for the help man :slight_smile:
