Unable to download a new sketch
Hi.
Just received my MKRFOX and it has been working for 3 days :frowning:
I am now unable to download a new sketch
It has been working under windows, now it fails.
I have just installed IDE on another PC under linux.
Does not work.
When I plug, I see in dmesg:
[ 2836.109786] usb 2-7: new full-speed USB device number 39 using ohci-pci
[ 2836.289789] usb 2-7: device descriptor read/64, error -62
[ 2836.573761] usb 2-7: device descriptor read/64, error -62
[ 2836.853745] usb 2-7: new full-speed USB device number 40 using ohci-pci
[ 2837.085509] usb 2-7: New USB device found, idVendor=2341, idProduct=8050
[ 2837.085517] usb 2-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2837.085521] usb 2-7: Product: Arduino MKRFox1200
[ 2837.085524] usb 2-7: Manufacturer: Arduino LLC
[ 2837.089712] cdc_acm 2-7:1.0: ttyACM0: USB ACM device
so it gets the board on ttyACM0.
When I try to download:
[ 2920.834745] cdc_acm 2-7:1.0: failed to set dtr/rts
[ 2920.846493] cdc_acm 2-7:1.0: failed to set dtr/rts
[ 2926.850361] cdc_acm 2-7:1.0: failed to set dtr/rts
[ 2927.656375] cdc_acm 2-7:1.0: failed to set dtr/rts
[ 2927.659364] cdc_acm 2-7:1.0: failed to set dtr/rts
[ 2928.765337] cdc_acm 2-7:1.0: failed to set dtr/rts
Error in IDE :
No device found on ttyACM0
Une erreur est survenue lors du transfert du croquis
If I reset:
[ 3319.369417] usb 2-7: USB disconnect, device number 42
[ 3320.583055] usb 2-7: new full-speed USB device number 43 using ohci-pci
[ 3320.763056] usb 2-7: device descriptor read/64, error -62
[ 3321.047056] usb 2-7: device descriptor read/64, error -62
[ 3321.327065] usb 2-7: new full-speed USB device number 44 using ohci-pci
[ 3321.507073] usb 2-7: device descriptor read/64, error -62
[ 3321.791066] usb 2-7: device descriptor read/64, error -62
[ 3322.071068] usb 2-7: new full-speed USB device number 45 using ohci-pci
[ 3322.479071] usb 2-7: device not accepting address 45, error -62
[ 3322.655058] usb 2-7: new full-speed USB device number 46 using ohci-pci
[ 3323.063076] usb 2-7: device not accepting address 46, error -62
[ 3323.063126] usb usb2-port7: unable to enumerate USB device
---> no board found.
Under windows:
On plug : in IDE find one serial with board MKR1200. download fails
On reset : windows popup dealing with malfunction of periph
The board still works as it can send message on sigfox network.
in the last version I downloaded, I removed all traces
removed at the beginning :
while(!Serial) {};
device enters deep sleep very quickly .
any idea ?
Thx
Chris
Under windows,
First off you should not really need the "while(serial)" command as it will just sit there waiting for a serial connection so in autonomous mode that would just sit there doing nothing.
Have you tried the "quickly double tap the reset button" trick to put it into bootloader mode ?
It will show up on a different serial port btw when you do that. Once you have it in bootloader mode throw a simple sketch up such as blink etc.
That should put you back in control of it.
Also remember that whilst not 100% the same as an MKR1000 a lot of things from that board in terms of tricks and tips should also work with the fox variant.
Yo !
You saved my life.
Well at least my board !
It works like a charm :slight_smile:
I didn’t know the trick.
Works for all the arduino or only for this proc ?
Thx
It works for a few boards but the timing is a little different for some.
