I'm trying to load FW to a target board. I worked on this board for about 3 yrs and I have forgotten how I did it then. My instructions require loading the bootloader for the ATMEGA328 first. When I try to "burn bootloader" I get the error attached.
ATTINY and 328 are not the same.
Something is amiss in your setup or hopes.
Are you trying to burn the fuses on an ATTINY or a 328 ?
Lots more detail please ?
(deleted)
USBTiny = USBTinyISP. Nothing to do with attiny (other than the fact that it usually uses an attiny internally, running VUSB, while the USBAsps usually use a atmega8 or atmega88).
Do you have a USBTinyISP device connected to your computer's USB port, and plugged into the ISP header (or appropriate pins) on the board you are trying to bootload?
Bootloading requires a piece of hardware - an ISP programmer - connected to the target. This can be a USBTinyISP or USBAsp standalone programmer (I recommend USBAsp), or an arduino running ArduinoAsISP. There are a huge number of guides on this process.
Also, as others have said, never post pictures of text. There's even a button you can click to copy it to the clipboard, and paste it as text. So we don't have to download it to view it
Here is my answer (It's up to you to decode)
Decode this. ![]()
01001101 01100101 01110010 01110010 01111001 00100000 01000011 01101000 01110010 01101001 01110011 01110100 01101101 01100001 01110011 00100000 01100001 01101110 01100100 00100000 01001000 01100001 01110000 01110000 01111001 00100000 01001110 01100101 01110111 00100000 01011001 01100101 01100001 01110010 00101110
