Unable to drive 2n2907 transistor
I am having problems getting my board to drive a 2n2907 transistor and could use some ideas from the community.
First, if I simply run the board bare, this gives me roughly 5-Volts on pin A7:
	pinMode(A7, OUTPUT);
	digitalWrite(A7, HIGH);
and this gives me 0.001V on pin A7:
	digitalWrite(A7, LOW);
I have also tested the above on pin D13 with the same behavior.
I have a PNP transistor 2n2907 that I can manually drive without any issues at +5V on the collector if I use a 1kohm resistor on the base, connected to ground. The problem is that once I connect it to the arduino board on, I am unable to drive the transistor with any measureable change I cannot turn the transistor on or off - it simply floats its emitter, and shifts roughly 0.2V between being pulled high and low through the Arduino. This simple test doesn't work to turn the transistor on.
Is there something that I'm doing wrong here? Thanks in advance!
If this is a pro mini, you cannot use A6 or A7 as outputs.
larryd:
Nano board - I believe A0-A7 should all be usable.
I still experience the same issue on D13, which is commonly used in example projects online.
A Nano uses the same controller chip as a pro mini, A6 and A7 cannot be used as outputs.
Atmega328.
Show us a good schematic of your circuit.
Show us a good image of your wiring.
larryd:
Atmega328.
Thanks for the help - I got it working fine on pin D4. "Analog only" on A6/A7 I took as not pwm, int, etc, but still working for basic in/out. Didn't see mention in any pinouts of it being analog IN ONLY.
Not sure why I had issues getting D13 going. I don't need it, so I will leave on D5 since PWM will probably work better for me anyway.
