Unable to get the specified library .What to do.? I have to include this in to my code
https://somosioticos.com/archivos/separador.zip
That I know baby. I am unable to downtown that specified library.
the library Separador (somosioticos.com - This website is for sale! - somosioticos Resources and Information.) has been included. With this library, the information sent in a string format from the smartphone is separated into numbers that can be read by the Arduino.
Reading your original post, it was quite clear to me that you were asking how to install a library to the IDE from a zip file. I think most forum members would interpret your question in the same way. So I posted a link to instructions how to do that.
I don't understand the purpose of your second post. How is the article related to the library you want to install?
Your third post sounds very confused and frustrated. I am no longer certain what help you are asking the forum for.
The link to the zip file you posted is broken. Is this what you need help from the forum with? To find a working link to that library?
The library just splits the string of characters at the specified delimiter. It is quite possible to write such code on your own, for example, using the strtok() function or using Arduino libraries similar in functionality to Separador
https://www.arduino.cc/reference/en/libraries/stringsplitter/
and many others
- Software design
2.1. Arduino Sketch
The Arduino script presented in this section shows the code used to perform the
electrochemical measurements with the Arduino Nano microcontroller. To facilitate
the data obtention from the mobile application, the library Separador
numbers that can be read by the Arduino. If needed, the latest Arduino IDE can be
downloaded from: https://www.arduino.cc/en/Main/Software.
// Script starts
#include <Separador.h>
Separador s; // Library to separate the obtained results from the smartphone
// Circuit variables definition
int a = 9; // PWM output pin, 254 resolution bits
int ap = 10; // +5V supply for opamp
int an = 7; // ICL7660 supply, turns +5V to -5V for opamp
int a1 = 12; // ICL7660 supply, turns +5V to -5V
int a2 = 2; // +5V for Bluetooth module
int R2 = 330; // Used in operating potential window equation
int R3 = 510;
int R4 = 200;
int val ;
float ct = A0; // ADC analog input pin, 1024 resolution bits
float c; // Current in bits
float cc;
// Redefinition of variables obtained from the smartphone
float Estep;
int t;
int t_print;
TCCR1B = TCCR1B & B11111000 | B00000001; // Changes pin 9 frequency to 3.1kHz
pinMode(a,OUTPUT); // Output pin
pinMode(a1,OUTPUT);
pinMode(a2,OUTPUT);
pinMode(ap,OUTPUT);
pinMode(an,OUTPUT);
pinMode(ct,INPUT); // Input pin, current lecture
delay(2500);
digitalWrite(an,1); // Negative supply of opamp
digitalWrite(ap,1); // Positive supply of opamp
delay(30000);
digitalWrite(a2,1); // Bluetooth on
delay(5000); // Time (ms)
if (Serial.available()){
String e = Serial.readString();
String e1 = s.separa(e,',',0);
String e2 = s.separa(e,',',1);
String e3 = s.separa(e,',',2);
String e4 = s.separa(e,',',3);
String e5 = s.separa(e,',',4);
String e6 = s.separa(e,',',5);
String e7 = s.separa(e,',',6);
String e8 = s.separa(e,',',7);
int ee1 = e1.toInt(); // E0 mV
int ee2 = e2.toInt(); // Ei mV
int ee3 = e3.toInt(); // Ef mV
int ee4 = e4.toInt(); // Scan speed mV/s (vb)
int ee5 = e5.toInt(); // Cycle number
int ee6 = e6.toInt(); // Estep mV and time_step ms for chronoamperometry
int ee7 = e7.toInt(); // Time of potential application
int tech = e8.toInt(); // Electrochemical technique number
float Eii = ee2/1000.0; // Input of initial V, the smaller value from -1.5V
to 1.5 V
float Ei = (Eii+(200.0/510.0)4.70); // Transformation of the initial
potential to Arduino
int ti = Ei(255.0/(5.5*(200.0/330.0)));
float Ei0 = ee1/1000.0;
float E0 = (Ei0+(200.0/510.0)4.70);
int start = E0(255.0/(5.5*(200.0/330.0)));
float Ef0 = ee3/1000.0; // Input of end potential, the greater number from
-1.5V to 1.5 V
float Ef = (Ef0+(200.0/510.0)4.7); // Transformation of the end potential
int fin = Ef(255.0/(5.5*(200.0/330.0))); // Final potential, Arduino
scale, Ei<Ef
int vb = ee4; // Scan rate, mV/s, max = 1280 mV/s
int const count = ee5; // Cycles number
float Potstep = ee5/255.0; // Fixed due to the DAC resolution
long t=(5000000L)/(256Lvb);
int time_tot = ee7-1000; // Time (ms)
int tot_time = time_tot/ee6;
int val;
// Electrochemical methods
switch (tech){
// ------ Chronoamperometry------
case 1:
digitalWrite(a1,1);
for(int n = 1; n < tot_time; n++){
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(ti);
Serial.print(";");
analogWrite(a,ti);
c = analogRead(ct);
cc = (0.472*(analogRead(ct))-226.1);
Estep = (1.843-(val0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(nee6);
Serial.print(";");
Serial.println(cc);
int sec = ee6*1000;
delay(sec);
// ------Linear voltammetry------
case 2:
digitalWrite(a1,1);
// Anodic scan
if (Ei < Ef) {
for(int n = 1; n <= count; n++){
for(int val = ti; val < fin; val++){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
8
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
-226.1);
Estep = (1.843
-(val*0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(Estep);
Serial.print(";");
Serial.println(cc);
delay(t);
// Cathodic scan
else if (Ei >= Ef) {
digitalWrite(a1,1);
for(int val = ti; val > fin; val--){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
-226.1);
Estep = (1.843
-(val*0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
// ------Cyclic voltammetry------
case 3:
digitalWrite(a1,1);
// Anodic scan
if (Ei < Ef) {
// Start the forward scan
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
-226.1);
Estep = (1.843
-(val0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
// Start the reverse scan
for(int val = fin; val > start; val--){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
cc = (0.472(analogRead(ct))
-226.1);
Estep = (1.843
-(val*0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
ti = start;
// Cathodic scan
//Start the forward scan
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
-226.1);
Estep = (1.843
-(val*0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
//Start the reverse scan
for(int val = fin; val < start; val++){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
-226.1);
Estep = (1.843
-(val*0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
ti=fin;
//Script ends
Please modify
Yes
No, it's your project and you who should modify the code... I just gave you advice on how to get around the problem of missing a library.
Try it yourself, if there will be problems - ask in the forum.
Tried .Library mismatched
