Unable to flash bootloader to Micro from UNO
Hi there,
I have created an Arduboy clone using an Arduino Micro. Which works perfectly, except one thing. It uses the Micro bootloader and the Arduboy uses the Leonardo bootloader. If i try to use a Arduboy flasher, it won't detect the Arduboy Clone since they search for a Leonardo board. Since the Leonardo and Micro use the same microcontroller (the MEGA32U4), i want to flash the Leonardo bootloader onto the Micro. But i am facing issues while burning the bootloader. I am using an Arduino UNO as ISP. When i press burn bootloader all i see is that the display on the Arduboy clone flashes and then i receive this error message:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Sander\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
I have connected the Arduino UNO to the ICSP connector on the Micro like this:
(The numbers indicate to which pin they are connected to the UNO)
[10] [13] [12]
[GND] [11] [5V]
What is going wrong? And how can i fix this?
I'm not sure if this information would help, but the display is connected using SPI
Thanks in advance! :slight_smile:
Did you disconnect the display while uploading ? It could be interfering with programming..
DrAzzy:
No i haven't, do you think this is the issue? If so, do i have to disconnect every SPI pin of the display? I'd rather not want to disconnect all of them since they are soldered in :confused:
Not knowing the details of the display, I couldn't say. MISO is the pin most frequently problematic.
DrAzzy:
I am using a 128x64 SPI display with the SSD1306 controller. So you think i'll just have to disconnect the MISO pin and then try again?
