Hi there, i am unable to flash the D1 Mini ESP8266 Board using A Macbook Pro 2019 (2 Thunderbolt USB C) and the Arduino IDE 1.8.10 on Mac OS 10.15.2. I have the URL of the Bordmanager in the IDE, the driver installed and selected the Only Port option i have, being /dev/cu.URT0. Below is the Error the IDE puts out.
Please help :-\
Cheers Andrew
Arduino: 1.8.10 (Mac OS X), Board: "WeMos D1 R1, 80 MHz, Flash, Disabled (new can abort), All SSL ciphers (most compatible), 4MB (FS:none OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
Executable segment sizes:
IROM : 227612 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26768 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 672 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 256304 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26804 bytes (32%) of dynamic memory, leaving 55116 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port /dev/cu.URT0
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "/Users/artifex/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "/Users/artifex/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 2890, in main
esp.connect(args.before)
File "/Users/artifex/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
the selected serial port _
does not exist or your board is not connected
option enabled in File -> Preferences.
