Unable to get FT232R drivers loaded under Windows 7 64bit
Thank you, not it clear.
Vincent get’s the glory. Thanks for finding the solution. I saw that the PID in the .inf file didn’t match that shown using USBView but I hadn’t gotten around to trying it. The remaining question in my mind is how did the PID get set to 0000. I looked at the .inf file in the Arduino-1.05r2 download that I originally used and which worked and the PID there is 6001, so at some point the PID in my Arduino Nano must have matched one of the 6000 series PIDS. Go figure.
Thanks Vincent. Your solution works great.
Mine has FTDIBUS\COMPORT&VID_0403&PID_6001
Is that programmable? I see a whole bunch of application notes http://www.ftdichip.com/Support/Documents/AppNotes.htm
And the FT_PROG Utility http://www.ftdichip.com/Support/Utilities.htm#FT_Prog
Oops - didn't see the 2nd page of comments before I posted.
I have received the following response from FTDI:
We have investigated the device information that you submitted. This information indicates that the FT232R device is not a Genuine FTDI product. As this device is not genuine it will not operate with FTDI`s certified drivers.
We recommend to all our customers to guarantee genuine FTDI products please purchase either from FTDI directly or from one of our authorised distributors. Please follow this link to locate your local distributor: FTDI Sales Network
For more information please refer to FTDI`s counterfeit statement and driver license agreement.
I think this is also a problem in macs. Does anyone has a solution for Mac? (I tried peering into the FTDI dmg file, but it is binary, so I don't think you can change text like the inf file in windows).
This is interesting , in the INF file for the latest FTDI driver 2.12.00 this text has appeared
; Copyright © 2000-2014 Future Technology Devices International Limited ; ; USB serial port driver installation file for Windows 2000, XP, Server 2003, Vista, Server 2008, ; Windows 7, Server 2008 R2, Windows 8, Windows 8.1 and Server 2012 R2. ; ; ; IMPORTANT NOTICE: PLEASE READ CAREFULLY BEFORE INSTALLING THE RELEVANT ; SOFTWARE: This licence agreement (Licence) is a legal agreement between you (Licensee or ; you) and Future Technology Devices International Limited of 2 Seaward Place, Centurion Business ; Park, Glasgow G41 1HH, Scotland (UK Company Number SC136640) (Licensor or we) for use of ; driver software provided by the Licensor(Software). ; ; BY INSTALLING OR USING THIS SOFTWARE YOU AGREE TO THE TERMS OF THIS LICENCE ; WHICH WILL BIND YOU. IF YOU DO NOT AGREE TO THE TERMS OF THIS LICENCE, WE ARE ; UNWILLING TO LICENSE THE SOFTWARE TO YOU AND YOU MUST DISCONTINUE ; INSTALLATION OF THE SOFTWARE NOW. ; ; 1. GRANT AND SCOPE OF LICENCE ; ; 1.1 In consideration of you agreeing to abide by the terms of this Licence, the Licensor hereby ; grants to you a non-exclusive, non-transferable, royalty free licence to use the Software on ; the terms of this Licence. ; ; 1.2 In this Licence a "Genuine FTDI Component" means an item of hardware that was ; manufactured for, and sold by, the Licensor or a member of the Licensor's group of ; companies. It does not include any counterfeit or fake products. ; ; 1.3 If you are a manufacturer of a device that includes a Genuine FTDI Component (each a ; "Device") then you may install the Software onto that device. If you are a seller or distributor ; of a Device then you may distribute the Software with the Device. If you are a user of a ; Device then you may install the Software on the Device, or onto a computer system in order ; to use the Device. ; ; 1.4 In each of those cases you may: ; ; 1.4.1 install and use the Software for your purposes only; and ; ; 1.4.2 only use the Software in conjunction with products based on and/or incorporating a ; Genuine FTDI Component. ; ; 1.5 The Software will not function properly on or with a component that is not a Genuine FTDI ; Component. Use of the Software as a driver for, or installation of the Software onto, a ; component that is not a Genuine FTDI Component, including without limitation counterfeit ; components, MAY IRRETRIEVABLY DAMAGE THAT COMPONENT. It is the Licensee's ; responsibility to make sure that all chips it installs the Software on, or uses the Software as a ; driver for, are Genuine FTDI Components. If in doubt then contact the Licensor.
.. continues....
(my highlights)
You have all read and agreed to that haven't you? :)
So it seems that FTDI are now deliberately disabling counterfeit devices.
The license stated in the INF file is not legally binding, since the driver is installed automatically without the user seeing and given the opportunity to decline the agreement [IANAL]. Disabling user's property is probably illegal, but I doubt you'd win any suit in court.
FTDI are perfectly within their rights to only support genuine products, but I am not sure disabling clones is a sensible tactic, particularly when there is a trivially easy way to circumvent it. They are probably looking forward to the day when only Microsoft approved drivers can be installed on Windows, and it is a crime to tamper with your Windows installation!
I didn't see anything in the INF file that disables counterfeits, so either the change happened in an earlier release or more likely the code is in the binary drivers.
The advice to "only buy from FTDI authorised sellers" may as well be "don't buy FTDI", since not even big suppliers like RS and Farnell are authorised sellers. You'll be ok with Mouser and Digikey though :)
The problem of counterfeit FTDI chips and FTDI drivers trying to detect them has been around for a while, so it may just be coincidence that people are finding devices stop working now. If you plug an old device into a USB port that has never been used with that device, Windows downloads the latest driver (unless you disabled that) rather than use the already installed driver.
There is a fascinating page here literally taking the lid off http://zeptobars.ru/en/read/FTDI-FT232RL-real-vs-fake-supereal
Having also come across this problem I have downloaded the new FTDI drivers and tried the two newest in the list. While they install and I am able to apply them to my arduiono nano, I get the following error in the IDE when trying to upload code:
processing.app.SerialException: Serial port ‘COM3’ already in use. Try quiting any programs that may be using it.
at processing.app.Serial.(Serial.java:171)
at processing.app.Serial.(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:619)
processing.app.debug.RunnerException: Serial port ‘COM3’ already in use. Try quiting any programs that may be using it.
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:101)
It basically tells me that the COM port is already in use. I’ve tried a reboot and also clearing out the list of coms ports in windows to no avail…
Am I missing something here? (it is late…) I think a section of this thread was removed for legal reasons. Was that an important bit of info? Am I ultimately looking at buying new boards and rebuilding my project?
I think this attempt is going to backfire on FTDI with the hobbyist market. People working on projects without onboard UARTs (Pro Mini, bare uCs on boards, etc.) are just going to move to another UART maker rather than deal with having to buy FTDIs sight unseen with no way to check authenticity as they have to do in many cases.
I think this will encourage purchase of FTDI chips from legit companies vs counterfeit stuff from e-bay. I don't buy any ICs from ebay except WS28xx as that's the only place to get them. Digikey, Mouser, Avnet, tayda for MAX7291 even tho they might be fake - Maxim told me Tayda is not an authorized reseller. Newark if I get desperate. I'll have to check the FTDI modules I bought from Tinyosshop.com. I suppose they could use Atmega8U2 chips that are programmed, a la Arduino USB/Serial http://arduino.cc/en/Main/USBSerial
or Prolific chips, or CH403 (?) chips, or Cypress chips, or ...
Win7Pro didn't change my FTDI driver, altho Win8.1 seems to have on MrsCrossRoads' laptop. FTDI is always gonna work tho unless Arduino screws up the IDE on us.
Its not so easy in some countries. Here in Japan of the two authorized distributors listed by FTDI, one no longer seems to sell FTDI products and the other does not deal in low-quantity orders. Hence the hobbyist is left to rely on ad-hoc imported stuff, which in many cases have to be bought sight-unseen.
Can be sight-unseen, but can still buy from reputable companies - Newark, Farnell, RS, Digikey - many ship globally: http://www.digikey.com/us/en/International/global.html
I was unsure whether FTDI were doing the right thing, but I think I have changed my mind. Counterfeit chips are a big problem though often not talked about. I know that even reputable companies will go to the grey market to get stock if they need shorter lead times than the official disties, and risk picking up counterfeit parts. An example is Olimex, who were unfortunate to pick up some fakes. https://www.olimex.com/forum/index.php?topic=2031.0
The problem with fakes is not just loss of revenue for IP holder, but the fakes are simply lower quality compared to genuine parts. Prolific chips were widely copied, people had problems with what they thought were Prolific chips and I think their reputation suffered because of it. I am sure FTDI don't want the same thing to happen. I'll bet a lot of comms problems people have are down to fake chips.
So while it is pretty harsh if you have boards that stop working, I think I would prefer to know I have a genuine part rather than a fake that is going to give unreliable performance now or in the future. I've tried most of my boards with FT232 and they all seem to be ok, I might think differently otherwise!
Just to be clear, the workaround I described above is to make the driver work with the defective chips, not only FT_PROG!
I don’t see the workaround.
What is exactly the workaround, i have the same issues.
I have read the postings over and over but i don’t see a description of the workaround, am i missing something?
Workaround fakes the VID/PID info somehow. If you select: Control Panel:System: Device Manager: Ports: right click on USB device:Properties: Details:Hardware IDs, good one shows this: ftdibus\comport&vid_0403&pid_6001
Counterfeits will have 0s instead I think.
I has the same issues?and Hardware ID same as USB\VID_0403&PID_0000&REV_0600 Did FT_PROG works? Or there's another workaround better?
That is what i have to, but what is the workaround?
I have already changed the *.inf files, and replaced 6001 with 0000, but that didn't work. Help
Thumb Up for Amazon. They will send UPS here to pick up my 2 SainSmart Nano v3.0 boards that won’t communicate. Paid return, no questions. I did report counterfeit FDTI devices.
Thanks to this Forum!
Mick
