I’m trying to use the digital potentiometer MCP4151 (I tried both the models with 5 and 10 KOhms resistance) to replace a classical potentiometer, the goal being to be able to vary the voltage between (approximately) 0 and 5V.
I tried to use this example, which I think I adapted for my model of micro controller and my board (Arduino Mega).
It kind of work, but not totally the way I expected. First, the maximum voltage I get on the wiper output is around 3.9V, while I’m feeding it with the 5V from Arduino. Even if I send it 255 (well at least I think I do) it still never goes higher.
Secondly, I’m not sure the resistance is really changing in a linear fashion. When I increment the data byte sent to set the resistance value bit by bit, there are some steps at which the output voltage is not modified at all, and when it is it’s only by 0.01V. And after reaching a certain point it then increases faster and eventually reaches 3.92V when I send 255.
I know this is a very peculiar case and not many people is using this particuliar microcontoller, but I was wondering if by chance someone ever ran into a similar issue
Also - terminology - the microcontroller is the arduino mega (well, the ATmega2560 on the arduino mega). The MCP4151 is a digital potentiometer, not a microcontroller.
Okay sorry I'm too dumb and deserve death by fire, I just had a resistor and led wired on the wiper output, in parallel with the arduino's analog pin. I unplugged it and now it's working perfectly. I guess the arduino's 5V couldn't feed enough current to both or something...
francoisdtf:
It's not the Arduino's 5v that was unable to supply it, you were putting a load in series with a large (high value) resistor. The LED will draw current and throw off the voltage divider. Since the full scale of that pot is at least 5k, while the resistor in series with the LED is probably under 1k; once the voltage on the output is high enough that the LED begins to conduct, that will dominate, and start to throw off the results.
