Unable to get readings on LCD
I am trying to display the values indicated right at the bottom of the code. For some reason they do not show up. I want it to loop like the data logging information. Any suggestions will be hugely appreciated. Thank you:
#include <SD.h>
#include <Wire.h>
#include <Adafruit_INA219.h>
#include "RTClib.h"
#include <Adafruit_Sensor.h>
#include "Adafruit_TSL2591.h"
#include <LiquidCrystal.h>
File myFile;
Adafruit_INA219 ina219;
RTC_DS1307 RTC;
int temperaturePin = 0;
Adafruit_TSL2591 tsl = Adafruit_TSL2591(2591);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
ina219.begin();
Wire.begin();
RTC.begin();
lcd.begin(16, 2);
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(10)) {
Serial.println("initialization failed!");
return;
Serial.println("Starting Adafruit TSL2591 Test!");
if (tsl.begin())
Serial.println("Found a TSL2591 sensor");
Serial.println("No sensor found ... check your wiring?");
while (1);
/* Configure the sensor */
configureSensor();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(DATE, TIME));
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
void configureSensor(void)
tsl.setGain(TSL2591_GAIN_MED);
tsl.setTiming(TSL2591_INTEGRATIONTIME_100MS);
void unifiedSensorAPIRead(void)
/* Get a new sensor event */
sensors_event_t event;
tsl.getEvent(&event);
if ((event.light == 0) |
(event.light > 4294966000.0) |
(event.light <-4294966000.0))
/* If event.light = 0 lux the sensor is probably saturated /
and no reliable data could be generated! /
if event.light is +/- 4294967040 there was a float over/underflow */
Serial.println("Invalid data (adjust gain or timing)");
Serial.print(event.light); Serial.println(" lux");
void unifiedSensorAPIWrite(void)
myFile.println("Invalid data (adjust gain or timing)");
myFile.print(event.light); myFile.println(" lux");
void unifiedSensorAPILCD(void)
lcd.println("0 lux");
lcd.print(event.light); lcd.println(" lx");
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float loadvoltage = 0;
shuntvoltage = ina219.getShuntVoltage_mV();
busvoltage = ina219.getBusVoltage_V();
current_mA = ina219.getCurrent_mA();
loadvoltage = busvoltage + (shuntvoltage / 1000);
float temperature = getVoltage(temperaturePin);
temperature = (temperature - .5) * 100;
DateTime now = RTC.now();
myFile = SD.open("datalog.txt", FILE_WRITE);
Serial.print("Bus Voltage: "); Serial.print(busvoltage); Serial.println(" V");
Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV");
Serial.print("Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
Serial.print("Current: "); Serial.print(current_mA); Serial.println(" mA");
myFile.print("Bus Voltage: "); myFile.print(busvoltage); myFile.println(" V");
myFile.print("Shunt Voltage: "); myFile.print(shuntvoltage); myFile.println(" mV");
myFile.print("Load Voltage: "); myFile.print(loadvoltage); myFile.println(" V");
myFile.print("Current: "); myFile.print(current_mA); myFile.println(" mA");
unifiedSensorAPIRead();
unifiedSensorAPIWrite();
Serial.print("Temp: "); Serial.print(temperature); Serial.println(" degree Celsius");
myFile.print("Temp: "); myFile.print(temperature); myFile.println(" degree Celsius");
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
myFile.print(now.year(), DEC);
myFile.print('/');
myFile.print(now.month(), DEC);
myFile.print('/');
myFile.print(now.day(), DEC);
myFile.print(' ');
myFile.print(now.hour(), DEC);
myFile.print(':');
myFile.print(now.minute(), DEC);
myFile.print(':');
myFile.print(now.second(), DEC);
myFile.println();
Serial.println("");
myFile.println("");
// close the file:
myFile.close();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(busvoltage); lcd.print(" V");
lcd.print(current_mA); lcd.print(" mA");
lcd.setCursor(0, 1);
unifiedSensorAPILCD();
lcd.print(temperature); lcd.print(" C");
delay(5000);
float getVoltage(int pin)
return (analogRead(pin) * .004882814);
Please learn how to use the toolbuttons BEFORE posting.
Use the CODE button to post code, like this:
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
File myFile;
RTC_DS1307 RTC;
  ina219.begin();
  Wire.begin();
  RTC.begin();
  lcd.begin(16, 2);
    return;
  if (tsl.begin())
    while (1);
  configureSensor();
    RTC.adjust(DateTime(__DATE__, __TIME__));
    /* If event.light = 0 lux the sensor is probably saturated */
    /* and no reliable data could be generated! */
    /* if event.light is +/- 4294967040 there was a float over/underflow */
  Serial.print('/');
  Serial.print('/');
  Serial.print(' ');
  Serial.print(':');
  Serial.print(':');
  myFile.print('/');
  myFile.print('/');
  myFile.print(' ');
  myFile.print(':');
  myFile.print(':');
  myFile.println();
  Serial.println("");
  myFile.println("");
      // close the file:
  myFile.close();
 lcd.clear();
  delay(5000);
DO YOU SEE WHY ?
Are you able to get any data to appear on the LCD display - perhaps with another simpler program?
...R
Hi, how have you written this program, stage by stage or trying to get everything to work at once.
Robin2 's advice is very good, start by getting the LCD to display "Hello World" this will make sure that you have connections and contrast set.
Then add another function and get that working, saving you sketch under different names as you go.
Tom..... :slight_smile:
Hi. Thanks for getting back to me. I am trying to display the values in one go. The 'hello world' command works, suggesting that the LCD is wired correctly. I am unsure what sort of code to use to get the values to display. I have provided the code again. Thank you.
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
File myFile;
RTC_DS1307 RTC;
  ina219.begin();
  Wire.begin();
  RTC.begin();
  lcd.begin(16, 2);
    return;
  if (tsl.begin())
    while (1);
  configureSensor();
  Serial.print('/');
  Serial.print('/');
  Serial.print(' ');
  Serial.print(':');
  Serial.print(':');
  myFile.print('/');
  myFile.print('/');
  myFile.print(' ');
  myFile.print(':');
  myFile.print(':');
  myFile.println();
  Serial.println("");
  myFile.println("");
      // close the file:
  myFile.close();
 lcd.clear();
  delay(5000);
I suggest you make a copy of the helloWorld program and modify it to display the sort of data you want in your real project. Don't bother trying to get values from sensors - just "hardwire" them into some typical variables. For example
byte sensor1val = 12;
int sensor2val = 375;
Obviously use data types and values that are typical of what your real project will show.
When you know how to do it with the simple program you can transfer your knowledge to the real project.
...R
I think you want to use ||, not |
