Unable to install downloaded library
Have copied libraries from LCDWIKI.com to get libraries to control a 3.5" TFT display (LCDWIKI_GUI, LCDWIKI_KBV and TouchScreen) to the sketchbook location libraries folder in IDE 2.3.2. When I try to install the libraries they don't show up in the library list in the library manager with no error message. I have restarted the IDE several times with the same result.
Any help would be much appreciated
If you've copied the relevant libraries to your libraries folder, they're installed.
Hi @wtechlrw.
Library Manager only lists the libraries that are available for installation from Library Manager. So it is expected that any libraries that are not available for installation via Library Manager won't appear in Library Manager, even after you install them.
So it sounds like there is nothing amiss. If you have any problems while using the libraries, let us know. Otherwise you can proceed with your project without any concern about not seeing the libraries in Library Manager.
Thanks!! I thought the library manager would list all the installed libraries but it seems it only knows the ones installed through the manager and doesn't recognize libraries manually installed. Good info!
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
