Unable to launch on ubuntu
Hi
i downloaded the IDE 2.1.0 on ubuntu 22.04.2 LTS, using the zip or the appimage (same issue). I set the right to execute.
When I launch it, it logs the text below then nothing happens. any clue appreciated, Thanks!
Arduino IDE 2.1.0
Starting backend process. PID: 37548
[37523:0430/170401.840851:ERROR:browser_main_loop.cc(1400)] Unable to open X display.
The futex facility returned an unexpected error code.
Aborted (core dumped)
xxxxx@xxxxx:~/Applications$ node:internal/fs/utils:343
    throw err;
Error: ECONNABORTED: software caused connection abort, open '/tmp/.mount_arduinB1AR0T/resources/app/node_modules/node-log-rotate/lib/delete-log-files.js'
    at Object.openSync (node:fs:582:3)
    at Object.func [as openSync] (node:electron/js2c/asar_bundle:5:1800)
    at Object.readFileSync (node:fs:450:35)
    at Object.e.readFileSync (node:electron/js2c/asar_bundle:5:9148)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1138:18)
    at Module.load (node:internal/modules/cjs/loader:982:32)
    at Module._load (node:internal/modules/cjs/loader:823:12)
    at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
    at Module.require (node:internal/modules/cjs/loader:1006:19)
    at require (node:internal/modules/cjs/helpers:93:18) {
  errno: -103,
  syscall: 'open',
  code: 'ECONNABORTED',
  path: '/tmp/.mount_arduinB1AR0T/resources/app/node_modules/node-log-rotate/lib/delete-log-files.js'
Your topic has been moved to the dedicated IDE2.0 section of the forum.
Thanks for reporting it.
I am not on Linux, so I cannot give you an exact answer, but threads suggest that you might need to set the DISPLAY env variable and/or install and start the Xserver. If you're an experienced user, please see these threads if any of them solves the issue:
I am sure somebody from the forum with more experience with Linux can help if you get stuck.
