Unable to open Serial Plotter or Serial Monitor while sketch is uploaded
FIXED: I had board set at Arduino Mini and not Arduino Nano, which is what I'm using.
I apologize for the post. Is there a way to remove it?
Original issue:
Regardless of whether I have anything attached to my analog pins, when I run either the Serial Plotter or Serial Monitor while my sketch is uploaded, I get:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
In addition, it seems like my baud rate is being overriden.
This is what I get when I upload but before I try to open Serial Monitor / Serial Plotter:
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
Code:
 Serial.begin(9600); //9600 baud
  Serial.print("test"); //check to see if anything prints if serial monitor opens
I have two phototransistors attached to my mini (I'm pretty sure it's not made by arduino) and I want to be able to get a readout from both of them while my code is uploaded.
Originally, I had IDE 1.8.9, and was told to download a driver that would work for my "CH340" chip and to revert to 1.6.13.
I've also restarted my computer, uninstalled Arduino completely, and tried using the reset button on the mini.
Nothing changed.
Thanks for the help.
Thanks for taking the time to provide an update. I'm glad to see you found a solution. Enjoy!
Per
