Unable to print date and time in JSON format
I am trying to send the sensor DHT11 data to AWS cloud in JSON format for further analysations. I am able to send Temperature and Humidity values to the cloud in JSON format but unable to send time. I am using the NTP protocol to send date and time. I added all the necessary libraries and if i use
formattedDate = timeClient.getFormattedDate();
Serial.println(formattedDate);
This works fine. But I want to print it in JSON format so i am using
sprintf(payload,"{"timestamp":%s,"temperature":%f,"humidity":%f}",formattedDate,t,h);
Near timestamp it is showing question marks and some boxes. Can I declare a string as %s??
Is a string, or a String?
You are trying to format floats using %f but formatting floats using sprintf() in the Arduino IDE is not generally supported, hence the question marks. Convert the floats to strings before using them in sprintf()
See dtostrf()
UKHeliBob:
See dtostrf()
from the SE version of the question I know it is an esp32. there float works in sprintf
Not really an Arduino at all then.
It was good of the OP to give us all the relevant information
