Using a Samsung Pro Chromebook, Chrome OS Version 88.0.4324.208 (Official Build) (64-bit)
Chrome Version 88.0.4324.208 (Official Build) (64-bit)
Using a USB 3.0 port filtered through a USB2.0 powered hub
I had similar results using two older Chromebooks
Programs to load: Basic (empty) initial new program, Blink and Fade from the examples - see the attached images for part of code from the example Blink program.
The editor recognizes the Arduinoes when they are connected through USB
These programs all load and run using the stand-alone Arduino editor version 1.8.13
After an attempted upload, there is an error message in the bar at the bottom of the code source window: </> could not open board on /dev/ttyACMO
After the attempted upload, the Arduino board is flashing its Rx and Tx leds, the LED that would flash after loading Blink is on, and the editor no longer "sees" the Arduino
See also two images, one from before the upload, one from after.
Error log:
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:avr:leonardo -build-cache /tmp -build-path /tmp/140562685/build -verbose -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.serial-discovery.path=/home/builder/.arduino15/packages/builtin/tools/serial-discovery/1.1.0 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino9 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.xtensa-lx106-elf-gcc.path=/home/builder/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9 -prefs runtime.tools.esptool.path=/home/builder/.arduino15/packages/esp8266/tools/esptool/2.5.0-3-20ed2b9 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/industruino/tools/bossac/1.7.0-industruino -prefs runtime.tools.ctags.path=/home/builder/.arduino15/packages/builtin/tools/ctags/5.8-arduino11 -prefs runtime.tools.mkspiffs.path=/home/builder/.arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino2 -libraries /tmp/140562685/custom -libraries /tmp/140562685/pinned /tmp/140562685/Blink
Using board 'leonardo' from platform in folder: /home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2
Using core 'arduino' from platform in folder: /home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2
Detecting libraries used...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Leonardo\"" -I/home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2/variants/leonardo /tmp/140562685/build/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Leonardo\"" -I/home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2/variants/leonardo /tmp/140562685/build/sketch/Blink.ino.cpp -o /tmp/140562685/build/preproc/ctags_target_for_gcc_minus_e.cpp
/home/builder/.arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/140562685/build/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Leonardo\"" -I/home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/avr/1.8.2/variants/leonardo /tmp/140562685/build/sketch/Blink.ino.cpp -o /tmp/140562685/build/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/core/core_arduino_avr_leonardo_0fd389f0184d5a21fcc443ff311da7f1.a
Linking everything together...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o /tmp/140562685/build/Blink.ino.elf /tmp/140562685/build/sketch/Blink.ino.cpp.o /tmp/140562685/build/../../core/core_arduino_avr_leonardo_0fd389f0184d5a21fcc443ff311da7f1.a -L/tmp/140562685/build -lm
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/140562685/build/Blink.ino.elf /tmp/140562685/build/Blink.ino.eep
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy -O ihex -R .eeprom /tmp/140562685/build/Blink.ino.elf /tmp/140562685/build/Blink.ino.hex
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-size -A /tmp/140562685/build/Blink.ino.elf
Sketch uses 3956 bytes (13%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes (5%) of dynamic memory, leaving 2411 bytes for local variables. Maximum is 2560 bytes.
Upload started
Validating license ...
Programming with: avrgirl-arduino flash -f undefined -a leonardo -p /dev/ttyACM0
resetting board...
reset complete.
Please advise me.
