Hello i have a custom pcb using the DUE's atsam3x and i am having trouble reading from pololus QTRX sensors . Based on an actual board and pololus documentation i was able to reverse engineer the schematic and copied it on my own pcb. Basically the schematic is this
here is the schematics on the custom board. I have verified the connections and all are soldered properly. Damage to the part due to the desoldering process is also unlikely, i am confident that i desoldered and solderd it properly. Extra care was done with the temperature of the hot air.
Although the code i used is not using pololus library, it should still work because im sure pololus just also use digitalRead but pulsed to very the reading.
I would say Pololu pulses the LEDs to get any reading. If you constantly power the LEDs you only see any signal if you change the visible pattern.
pylon:
Yes that might be the case, but digitalRead should still be able to see some data. In my case im not getting any
I have tried using the library example sketch, and it still reads all zero on any colored surface, or with a flashlight
i should have tested the Pololu board before de soldering if it still working last time i checked was month ago
pylon:
Why should digitalRead return anything else than 0?
A flashlight makes no sense, the sensor is reflective. If I interpret the circuit correctly, it works only if your pulse the LEDs.
Im sorry i should been a lot clearer. I was expecting that when not using the library if i agitate the sensors with some flashlight or IRLED (dunno if this one really turned on because we cant see IR with our eyes).
I have tried the other example, it would seems that i got values that fluctuate not. Although the value got agitated at a range of around 10cm which is a lot farther than i remember last using it, which i can easly adjust the dimming levels.
I think you are right, i must really use the library inorder to get meaningfull data. Thanks Pylon i confirmed that the hardware is okay and will let the code handle the rest.
That's a lottery if you don't know the exact frequencies used by the Pololu solution. Additionally you would have to match exactly the read out time with your lighting change to see a reaction using that circuit. You won't see a constant value on your input if you provide constant light! The "pull-up" is a capacitor!
