in the last month Arduino was able give hex code when i pressed button on remote but now it is gives nothing can anyone help me to fix this
this is the code
#include <IRremote.h>
#include <SPI.h>
IRrecv ir(6);
void setup(){
ir.enableIRIn();
void loop(){
if (ir.decode()) {
unsigned long long int q = ir.decodedIRData.decodedRawData;
ir.resume();
Serial.println((unsigned)q);
Have you changed the code since it worked last ?
If the code has not changed then you have a hardware/wiring problem
Maybe new batteries in the remote....
xfpd
4
Point your remote directly at your phone camera. You will see the IR LED pulse if it is working.
Yes, the problem was with hardware i.e ir sensor
Now it's working
system
Closed
6
