I am using the MFRC522
library and I have custom logic based on the UID of the tag. The issue is that the custom code runs only if the serial monitor is open. If I upload the code and the serial monitor is closed, the RFID does not detect the tag (the custom code is not run). This is my code:
#include <MFRC522.h>
#define RST_PIN 9
#define SS_PIN 10
#define BLUELED 4
MFRC522 mfrc522(SS_PIN, RST_PIN);
boolean isOnRoad;
int bluelightOn;
unsigned long previousMillis, currentMillis;
unsigned long blueLightInterval = 1000;
SPI.begin();
mfrc522.PCD_Init();
pinMode(BLUELED, OUTPUT);
previousMillis = 0;
currentMillis = millis();
if (!isOnRoad) {
normalTrafficLights();
onRoad();
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
byte block;
byte len;
MFRC522::StatusCode status;
// if ( ! mfrc522.PICC_IsNewCardPresent()) {
// return;
// if ( ! mfrc522.PICC_ReadCardSerial()) {
// return;
if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial()) {
if ((mfrc522.uid.uidByte[0] == 0x72 &&
mfrc522.uid.uidByte[1] == 0xE5 &&
mfrc522.uid.uidByte[2] == 0x23 &&
mfrc522.uid.uidByte[3] == 0xD9) || (
mfrc522.uid.uidByte[0] == 0x25 &&
mfrc522.uid.uidByte[1] == 0xC4 &&
mfrc522.uid.uidByte[2] == 0xF5 &&
mfrc522.uid.uidByte[3] == 0xC2) || (
mfrc522.uid.uidByte[0] == 0x82 &&
mfrc522.uid.uidByte[1] == 0x82 &&
mfrc522.uid.uidByte[2] == 0x94 &&
mfrc522.uid.uidByte[3] == 0xDC)) {
isOnRoad = false;
mfrc522.PICC_HaltA();
mfrc522.PCD_StopCrypto1();
void onRoad() {
if (currentMillis - previousMillis >= blueLightInterval) {
bluelightOn = !bluelightOn;
digitalWrite(BLUELED, bluelightOn);
Any idea what might be happening?
