I'm a student & I'm new to the arduino so I apologize if this question is redundant. I am currently working on a project where I send values from a MPR121 to Unity, which then checks the values before sending a response back to the Arduino via BLE.
Unity is able to receive values via BLE from my Arduino...however it is not working the other way around. When I comment out my MPR121 code and stop sending MPRvalues to unity, the Arduino is then able to call blecharacteristic.written() as true and .read() to see what values have been sent.
#include <ArduinoBLE.h>
#include "LSM6DS3.h"
#include "Wire.h"
#include <Adafruit_MPR121.h>
#include "Adafruit_DRV2605.h"
#include <iostream>
#include <cstring>
LSM6DS3 myIMU(I2C_MODE, 0x6A); //I2C device address 0x6A
Adafruit_DRV2605 drv; //DRV Instantiation
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // Bluetooth® Low Energy LED Service
// Bluetooth® Low Energy LED Switch Characteristic - custom 128-bit UUID, read and writable by central
BLECharacteristic switchCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite | BLENotify, 200);
const int ledPin = LED_BUILTIN; // pin to use for the LED
char data;
Adafruit_MPR121 cap = Adafruit_MPR121();
// Change value to select which haptic effect to play
uint8_t effect = 58;
int mpr_values[12];
int x;
String mprData;
String temp;
char *buf;
//char space = " ";
// Pass argument 0-7 to select x I2C port
void TCA9548A(uint8_t bus) {
Wire.beginTransmission(0x70); // TCA9548A address
Wire.write(1 << bus); // send byte to select bus
Wire.endTransmission();
//Serial.print(bus);
// Initializes DRV2605L
void drvInit() {
TCA9548A(1);
drv.begin();
drv.selectLibrary(1);
// I2C trigger by sending 'go' command
// default, internal trigger when sending GO command
drv.setMode(DRV2605_MODE_INTTRIG);
// Starts BLE Service to connect with Unity
void bleInit() {
if (!BLE.begin()) {
Serial.println("starting Bluetooth® Low Energy module failed!");
while (1);
// set advertised local name and service UUID:
BLE.setLocalName("LED");
BLE.setAdvertisedService(ledService);
// add the characteristic to the service
ledService.addCharacteristic(switchCharacteristic);
// add service
BLE.addService(ledService);
// set the initial value for the characeristic:
switchCharacteristic.writeValue((byte) 0x00);
// start advertising
BLE.advertise();
Serial.println("BLE LED Peripheral");
// Prints out Accelerometer values
void printAccel() {
Serial.print("\nAccelerometer:\n");
Serial.print("X1 = ");
Serial.print(myIMU.readFloatAccelX(), 4);
Serial.print("\n");
Serial.print("Y1 = ");
Serial.print(myIMU.readFloatAccelY(), 4);
Serial.print("\n");
Serial.print("Z1 = ");
Serial.print(myIMU.readFloatAccelZ(), 4);
// This method stores filtered data from the MPR as a string array and converts it into a char type array to be sent
// to Unity
void printMPR() {
TCA9548A(0);
//Serial.print("MPR Readings:\n");
buf = (char*) malloc(sizeof(mpr_values));
for (x = 0; x <= 11; x++) {
mpr_values[x] = cap.filteredData(x);
temp = (String) mpr_values[x] + '\t';
mprData = mprData + temp;
temp = "";
//Serial.print(mprData);
//Serial.print("\n");
mprData.toCharArray(buf, sizeof(mpr_values));
mprData = "";
switchCharacteristic.writeValue(buf);
free(buf);
//delay(10);
// Method that sends a signal to the DRV2605L for haptics
void Touch() {
TCA9548A(1);
drv.setWaveform(0, effect); // play effect
drv.setWaveform(1, 0); // end waveform
// play the effect!
drv.go();
int convertData(const unsigned char data[], int length) {
int temp = 0;
for (int i = 0; i < length; i++) {
unsigned char b = data[i];
//if (b < 16) {
//Serial.print("0");
//Serial.println(b, HEX);
//Serial.println(b);
temp << 8;
temp += data[i];
Serial.print("Value Received: ");
Serial.print(temp);
Serial.print("\n");
return temp;
void checkThreshold() {
if (switchCharacteristic.written()) {
int temp = convertData(switchCharacteristic.value(), switchCharacteristic.valueLength());
if (temp == 1) {
Touch();
// Changes Arduino LED from ON to OFF. If !central.connected, then LED's stop blinking
//void bleLight() {
// if (switchCharacteristic.written()) {
// Serial.println("Updated");
// switchCharacteristic.read();
// int temp = convertData(switchCharacteristic.value(), switchCharacteristic.valueLength());
// if (temp == 99) {
// digitalWrite(ledPin, LOW);
// } else if (temp == 100) {
// digitalWrite(ledPin, HIGH);
Wire.begin();
drvInit();
// set LED pin to output mode
pinMode(ledPin, OUTPUT);
// begin initialization
while (!Serial);
//Call .begin() to configure the IMUs
if (myIMU.begin() != 0) {
Serial.println("Device error");
Serial.println("Device OK!");
// Init MPR on bus number 0
TCA9548A(0);
if (!cap.begin(0x5A)) {
Serial.println("MPR121 not found, check wiring?");
while (1);
Serial.println("MPR121 found!");
bleInit();
// listen for Bluetooth® Low Energy peripherals to connect:
BLEDevice central = BLE.central();
// if a BLE device(central) is connected to peripheral:
if (central) {
Serial.print("Connected to central: ");
Serial.println(central.address());
// while the central is still connected to peripheral:
while (central.connected()) {
delay(100);
Serial.println("Receiving value from Unity...");
if (temp == 1) {
Touch();
printMPR();
// when the central(BLE) disconnects, print it out:
Serial.print(F("Disconnected from central: "));
In printMPR I am using writeValue() to send an array of Chars to Unity. Unity then sends back a a response which I use the convertData() function to convert into a string, which I then check the value to determine if Touch() is activated or not.
I don't understand why my entire if statement in bleCharacteristic.written() is being skipped whenever printMPR() is being called. If I do not send the MPR values, everything works fine and I'm able to read values from Unity.
Help would be greatly appreciated!
